Heat - Electrical - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 12:48 PM   #1
heat
what the diference of 2 wire honeywell and 4 honeywell manual thermostat baseboard heat electric
zimako is offline   Reply With Quote
Old 11-29-2010, 12:57 PM   #2
the diference of 2 and 4 wire thermostat heatbaseboard heat honeywell
Old 11-29-2010, 02:16 PM   #3
Electrical Contractor
kbsparky's Avatar
Generally, when dealing with line voltage thermostats, a 2-wire unit is a single pole, and a 4-wire unit is a double pole.
Double pole thermostats will completely disconnect both legs of a circuit when it is placed in the "off" position. This qualifies the thermostat as a "disconnecting means" when properly wired.
Single pole thermostats do not have an "off" position.
-KB
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
Heat Pump set back GEAF HVAC 6 01-26-2009 08:49 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
