Old 09-11-2012, 11:55 PM   #1
HDMI went out with spark from the plug
I was moving around some plugs behind my tv set and there was a spark at the plug and it knocked both hmdi jacks on my tv. can these be fixed? It's not under warranty
Greg45 is offline   Reply With Quote
Old 09-12-2012, 07:38 AM   #2
Questions for you.
Were you connecting something new or were you adjusting an existing connection?
Which plug (exactly) did the spark appear at?
Were you connecting something correctly or did you accidentally touch two things that normally do not go together?
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
AllanJ is online now   Reply With Quote
Old 09-12-2012, 08:07 AM   #3
custom user
Don't rule out a static charge. If it's enough to hurt it's enough to zap delicate electronics.
JasperST is offline   Reply With Quote
Old 09-12-2012, 05:20 PM   #4
Yes, it was a powerstrip behind my tv and I was pushed the cords aside because my phone wasn't working. It then sparked at the plug as it was plugged in the the powersrip.
Old 09-12-2012, 06:14 PM   #5
bad news....your tv could probably get fixed......but it'd likely be far far cheaper to buy a new one.....
ryan50hrl is offline   Reply With Quote
Old 09-12-2012, 07:18 PM   #6
Try unplugging all of the cords from the TV including the power cord (write down how they were connected so you can put them back).
Wait five minutes.
Reconnect everything,
Old 09-12-2012, 10:36 PM   #7
custom user
Is it a flat panel display? Does it work with component cables? If so it may be like my Panasonic plasma and have add on or replaceable 'blade' cards for hmdi, audio, etc.
77 F100 Spark Plug Socket Size? jpearson311 Automotive Repairs 10 07-10-2012 10:17 AM
When you plug into outlet and light spark between plug, is this warning sign? Andee77 Electrical 2 11-01-2011 02:29 AM
Removing spark plug on Paslode Angled nailer solarant Tools 5 03-14-2011 05:08 PM
Spark Plug recommendations LordX Automotive Repairs 6 08-10-2009 03:12 PM
HDMI makes huge spark!!! cwcox2 Electrical 17 12-15-2008 09:18 PM
