-   -   HDMI went out with spark from the plug (http://www.diychatroom.com/f18/hdmi-went-out-spark-plug-156577/)
Greg45 09-11-2012 10:55 PM
I was moving around some plugs behind my tv set and there was a spark at the plug and it knocked both hmdi jacks on my tv. can these be fixed? It's not under warranty
AllanJ 09-12-2012 06:38 AM
Questions for you.
Were you connecting something new or were you adjusting an existing connection?
Which plug (exactly) did the spark appear at?
Were you connecting something correctly or did you accidentally touch two things that normally do not go together?
JasperST 09-12-2012 07:07 AM
Don't rule out a static charge. If it's enough to hurt it's enough to zap delicate electronics.
Greg45 09-12-2012 04:20 PM
Spark knocks out hdmi
Yes, it was a powerstrip behind my tv and I was pushed the cords aside because my phone wasn't working. It then sparked at the plug as it was plugged in the the powersrip.
ryan50hrl 09-12-2012 05:14 PM
bad news....your tv could probably get fixed......but it'd likely be far far cheaper to buy a new one.....
AllanJ 09-12-2012 06:18 PM
Try unplugging all of the cords from the TV including the power cord (write down how they were connected so you can put them back).
Wait five minutes.
Reconnect everything,
JasperST 09-12-2012 09:36 PM
Is it a flat panel display? Does it work with component cables? If so it may be like my Panasonic plasma and have add on or replaceable 'blade' cards for hmdi, audio, etc.
