HDMI Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 10-02-2011, 10:07 PM   #1
HDMI problem
I have picture but no sound with my HDMI connection from my laptop to my tv...how do I fix this?
Nursing2 is offline   Reply With Quote
Old 10-02-2011, 10:26 PM   #2
I=E/R
a7ecorsair's Avatar
Well, this is somewhat off topic for this forum but, does your laptop have in integrated HDMI port or are you using any type of converter box?
a7ecorsair is offline   Reply With Quote
Old 10-02-2011, 10:58 PM   #3
Rewards Points: 1,418
Is the laptop's HDMI output intended to output sound as well as the picture?
Is the app (program; application) you are running configured for sound, volume turned up, etc.?
Do you need to turn on sound and adjust the volume on a system app (such as a mixer) as well as each specific program?
Old 10-02-2011, 11:00 PM   #4
Is the app (program; application) you are running configured for sound, directing output to front versus rear channels, volume turned up, etc.?
Old 10-02-2011, 11:37 PM   #5
Rewards Points: 590
You might get more help in the Home Theater or PC forums. Scroll down further.
operagost is offline   Reply With Quote
Old 10-02-2011, 11:59 PM   #6
Rewards Points: 6,652
Your laptop has a DVI output, or you do not have your laptop set up properly if it is truly a hdmi output, so that sound will also output on the hdmi cable.
Old 10-03-2011, 07:27 AM   #7
Limited Experience
As the other reply indicated. You most likely have a DVI connection or internal circuit from your laptop. Which will require a separate audio cable from the laptop to the TV or sound system to be able to listen to things.
raleighthings is offline   Reply With Quote
Old 10-03-2011, 07:30 AM   #8
Rewards Points: 460
Alternately you may have to take sound out of laptop headphones jack (small male jack like on iPod headphones) to RCA jacks (white and red) on TV, same device input as the HDMI video input.
http://www.mwave.com/mwave/SKUSearch...%20RCA%20Audio
diyorpay is offline   Reply With Quote
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 09:01 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
