Hbr635(t49) Bulb Change - Electrical - DIY Chatroom Home Improvement Forum
Old 10-11-2012, 01:33 PM   #1
hbr635(t49) bulb change
The bulb for this unit does not come out easily. Is there a trick to taking it out? Please help.
This is a recessed lighting fixture. The bulb is of the push-in or pull-out variety, not like the traditional screw-in type. The problem is: the bulb does not pull-out. My question is how can I get the bulb out? I have attached a photo of the unit (specifically the label).
HenryRamirez is offline   Reply With Quote
Old 10-11-2012, 02:58 PM   #2
Oso954's Avatar
Rewards Points: 1,132
It would help if you told use what "this unit" is.
Also, what is your difficulty in removing the bulb ?
(can't reach it, can't get good grip, won't turn/pull, etc)
Oso954 is offline   Reply With Quote
Old 10-11-2012, 03:59 PM   #3
Common Sense Common Guy
Rewards Points: 161
The bulb types listed, A19 and PAR30, are both medium-base standard screw-in bulbs... are you sure it's not a screw-type? perhaps the socket's been replaced or something in the past?
What I see in the photo appears to be a CFL of some sort, its ballast up there. It *should* unscrew, or perhaps it's corroded in there. You may have to remove power from it, and work on it a bit to get that ballast unscrewed. I suspect your "push-pull" comment is due to the compact fluorescent tube coming loose and wiggling?
flasherz is offline   Reply With Quote
Old 10-11-2012, 04:17 PM   #4
Oso954's Avatar
That is a can light trim. If it is used with the listed cans, it is definitely a screw in bulb. If it is used with the wrong can, it could be anything.
Try grasping the bulb and turning counter-clockwise (lefty loosey).
The other common socket for CFLs is a GU-24. It requires about 1/8 of a turn CCW, before it will pull out. Putting a slight upward pressure (towards the socket) often helps.
Old 10-11-2012, 04:23 PM   #5
Oso954's Avatar
Does your bulb look like this ?
GU24 base
Old 10-11-2012, 06:08 PM   #6
Pure Genius
Rewards Points: 150
Is it a 2 or 4 pin lamp? If so wiggle amd pull
Dierte is offline   Reply With Quote
Tips for Removing GU10 Bulb? djdragan Electrical 5 12-12-2010 09:17 PM
Bulb within a bulb Yoyizit Electrical 10 01-02-2010 10:16 AM
Ultraviolet bulb blown morr6241 HVAC 12 06-06-2009 10:00 PM
Blown Ultraviolet bulb morr6241 Electrical 1 06-06-2009 06:42 PM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 03:52 PM
