HB &G Column Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 03-09-2007, 08:09 PM   #1
HB &G column wiring
I'm installing two 8x8x6'8 columns in my house to support a beam crossing a 16 foot span. These columns are HB&G square columns http://www.hbgcolumns.com/squarecolumns.html but what i want to know is that if i can cut in a box into the material without ruining the bearing load capacity... and i know a wire is supposed to be secured within 12 inches of a plug, but forgoe that thought right now please... hehe.
i was thinking if i use a Die grinding wheel and just install remodel boxes, i'll be all set. but if anyone has come across this anytime please drop me a line...
smallcrpt is offline   Reply With Quote
Old 03-09-2007, 08:18 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,878
I think the only one who can answer this is the maker of the columns.
I don't know about a "plug", but in new work yes, the rule general is secure within 12" of a box.
If the cable is fished into a finished space then no securing is required. As with most, the box MUST have a clamp of some sort though. The molded in clamps in PVC boxes are fine.
Fishing down a column does fit this description.
Speedy Petey is online now   Reply With Quote
Old 03-10-2007, 08:48 AM   #3
big thanks
I have an email out to some of their ppl to see if i can cut a hole in them. But no response yet. You figured they'd be waiting anxiously at their desks on a Sat morning to receive an email... but who knows...
thanks again
-chris
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Concrete patch for lally column footing? AllGoNoShow Building & Construction 6 10-21-2006 09:16 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
How safe is knob and tube wiring? jackdp Electrical 8 10-29-2005 11:50 AM
