Hayward Super Pump Overheating - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-01-2012, 12:30 PM   #16
Rewards Points: 58
The reason the motor is hot is because the motor is built with rolled steel, not cast iron. Heat is dissipated through the rolled steel frame. Rolled steel motors are intended to run fairly hot. Cast iron has ribs running the length of the motor and dissipate the heat over a much larger surface area. That is why cast iron frames feel much cooler to the touch.
If the current is good and there is no overheating, you are fine and need to do nothing but enjoy the pool.
Sump Pump Questions henlij Plumbing 22 03-16-2015 11:00 PM
Sump pump operation MikeKy55 Plumbing 16 05-11-2011 05:35 PM
hayward super pump earlyriserjj Electrical 2 04-20-2011 11:56 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 07:10 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
