Hayward Super Pump - Electrical - DIY Chatroom Home Improvement Forum
Old 04-20-2011, 06:16 PM   #1
hayward super pump
what awg is required from the time clock to the motor?
earlyriserjj is offline   Reply With Quote
Old 04-20-2011, 06:31 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,970
What's the circuit breaker rating? Probably 20A, which means #12 wire.
mpoulton is offline   Reply With Quote
Old 04-20-2011, 10:56 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Just make sure the time clock is rated for 15 amp or more for motour useage and also double check if that clock motour required 120 or 240 volt source to run it.
If you can post the model number we can able help you with it.
Merci,
Marc
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Low Well Pressure, Submersible Well Pump, Help Please! tpolk Plumbing 7 11-13-2009 06:13 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
