Having Trouble Installing A Digital Timer - Electrical - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 07:42 PM   #1
Having trouble installing a digital timer
I've seen similar threads, but it seems each configuration is unique. I am trying to replace an old digital switch with a new one. The switch controls outside lights, and was originally controlled by a second switch in the garage, in addition to the inside switch which is being replaced. When I installed the original digital timer, which I believe was intended for a 3-way circuit, I put a jumper across the second switch in the garage. My replacement timer apparently is not intended for a 3-way switch. I installed it (after determining which wire is neutral), but the switch does nothing. I assume the problem has something to do with the 3-way circuit. Is there any way I can configure the circuit to work with this timer? I don't need to use the switch in the garage.
nefine is offline   Reply With Quote
Old 01-12-2012, 07:59 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by nefine View Post
I am trying to replace an old digital switch with a new one. <-- eh?
The switch controls outside lights, and was originally controlled by (along with?) a second switch in the garage.
When I installed the original switch, which I believe was intended for a 3-way circuit (bought that way because you have a 3 way circuit?), I put a jumper across the switch in the garage.
Focus on this statement and ideally with a picture of the device...
explain exactly what you did
I installed it (after determining which wire is neutral), (whoa! when did a neutral come into the picture.... explain pls) but the switch does nothing.
Yes, everything about this "has something to do with the 3-way circuit."
probably not... as you have described needing a 3way switch...
remember that jumper you cobbled together? explain pls
That's the best I can do with this.
Old 01-12-2012, 08:04 PM   #3
DIY staff
Rewards Points: 7,174
While trouble shooting---where is the power? where is the switch leg? In the timer box or the garage box?
Old 01-12-2012, 10:58 PM   #4
Licensed electrician
Rewards Points: 1,872
A white connected to the 3 way switch is not a neutral.
Old 01-12-2012, 11:17 PM   #5
I will check that....thx
Bbeemer1 is offline   Reply With Quote
Old 01-12-2012, 11:42 PM   #6
Jim, is it possible that the the problem is at the fan? That is also where the 3 way wire changes to 2 wire. At the light both the black and white are hot.
Tags
3-way switch , digital timer
Installation of a SunSmart Digital Timer PJR Electrical 4 04-26-2012 06:33 AM
GE SunSmart Digital TImer lilacorn1956 General DIY Discussions 4 04-23-2012 05:37 PM
3-way sunsmat digital timer install question pasadena4 Electrical 1 10-20-2011 07:33 AM
Help Installing lighting timer switch Katdav Electrical 2 11-27-2010 10:13 AM
Help installing Leviton programmable timer in old house nitrous Electrical 4 11-03-2010 06:41 AM
