#31 | |
having trouble with the gfci trippingQuote:
#32 |
Electrical Contractor
Just to clear something up, when I say "back stabbed" I'm talking about receptacles and switches where you just "stab" the wire in the back and it has a spring clip that holds the wire in place. I don't want to confuse this with back wired. Most gfi's are "back-wired" as is commercial grade receptacles and switches. Also, if I stand corrected, what I think you're talking about is a gfi being rated 20 amps and 20 amps for feed through and 15 if you're feeding others off of it.
#33 |
Power Gen/RS Engineer
10-4.
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves,"You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." - George Carlin |
#34 |
When is fishing season?
A GFI receptacle does not have backstab connections, it is backwired. They are 2 totally different things. A backwire uses a pressure plate that is tightened using the screws on the side. There are no restrictions for it saying you can only use 14awg wire and a 15 amp breaker.
I DON'T OWN MY HOUSE... MY HOUSE OWNS ME!
#35 |
Electrician
I have never seen a GFCI that could actually be back stabbed... like others have stated, only pressure plates, and they are NOT the same thing.
#36 |
having trouble with the gfci tripping |
#37 | |
Backwire - This also has holes in the back, but when the wire goes in it gets sandwiched between 2 plates, and when the screw on the side is tighened, it squeezes the wire inbetween the 2 plates. Screw - Pretty self explainatory...the screws on the side of the outlet. Wrap the wire around the screw the same direction the screw is going to turn.
#38 |
Thank You!
| Display Modes | |
| Freezer tripping GFCI | davidclements | Appliances | 40 | 10-15-2010 11:38 PM |
| New GFCI Breaker Tripping w/ 3-way Flourescents | BigJimmy | Electrical | 8 | 12-29-2008 03:29 PM |
| Hot Tub GFCI Grounding Question | kearnak1420 | Electrical | 3 | 04-30-2008 06:48 PM |
| 20 Amp Breaker tripping with GFCI | panhandlion | Electrical | 7 | 12-12-2007 09:59 PM |
| GFCI questions | 5circles | Electrical | 4 | 11-05-2007 09:24 PM |
