Having An Issue With My Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 11-29-2009, 10:19 PM   #1
Having an issue with my switch
In my house for years I have had this problem where I had to turn one switch on for the other one to turn the light on is this an issue where in 1 of my 3-way, the travellers or crossed or what else could this be. Thanks
prestige is offline   Reply With Quote
Old 11-29-2009, 10:36 PM   #2
Sometimes people do not wire things properly. It may be that there were not enough wires to install a proper 3-way switch set-up and they did not bother to run new wires.
How two 3-way switches are wired (can be differences)...
Billy_Bob is offline   Reply With Quote
Old 11-29-2009, 10:39 PM   #3
This is called a California 3-way...
Old 11-29-2009, 10:41 PM   #4
California 3-way with two loads...
Old 11-30-2009, 07:35 AM   #5
Just call me Andrew
Rewards Points: 1,020
Prestige, Are you saying:
If switch A is on, switch B controls the light.
If switch A is off, the light does not turn on, regardless of the position of switch B.
If so, it sounds like you are either missing a traveler, or that switch A is not a 3-way switch. Can you describe the wires in each of your switch boxes?
secutanudu is offline   Reply With Quote
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 12:43 PM
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 01:09 AM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 01:17 PM
To Switch loop or not to switch loop beezlebub03 Electrical 7 06-17-2008 07:04 PM
ceiling fan dimmer switch issue irich Electrical 4 02-10-2008 11:23 PM
