Have Questions About Adding A 60amp Subpanel - Electrical - DIY Chatroom Home Improvement Forum
Old 05-12-2010, 10:15 PM   #1
Rewards Points: 152
Have questions about adding a 60amp subpanel
I want to add a 60 amp subpanel just to add some circuits in the garage. I wanted to know, can i install a 60 amp breaker on the main panel to be the disconnect and service for the sub panel, or do i have to put a splitter between the main panel and subpanel and change the wire coming into the house?
My house has 100amp service. Im not gonna be putting a heavy load in these circuits.
One more question, when it comes to grounding the subpanel, can i bond it to the main panel or do i have the ground the subpanel differently and put a different ground rod. My house is old and i doubt i have a ground rod.
humberguy is offline   Reply With Quote
Old 05-12-2010, 10:18 PM   #2
Attached garage ?
Usually you put the 60a 240v breaker in the main panel to feed the sub
Old 05-12-2010, 10:21 PM   #3
Rewards Points: 152
yea, the garage is attached. Im still debating, i might put it in the garage, or i leave the sub panel in the house.
Old 05-12-2010, 10:34 PM   #4
Attached does not need a grounding rod
Grounding to rod occurs thru the Main panel
I always use a panel with a main shut-off breaker for a sub
Decide where you will use the mosts circuits in th sub - house or garage
And if there is easy access to house to reset breakers
Old 05-13-2010, 12:12 AM   #5
Rewards Points: 152
thanks for the response scuba, but i have one more question. If i use a 60amp breaker for the sub panel. Do i bond the neutral to the ground in the subpanel? Or do i leave the neutral and ground unbonded?
Old 05-13-2010, 12:34 AM   #6
Mad Scientist
Neutral and ground must remain separate in a sub-panel. In many cases this means purchasing an add-in ground bar kit for your sub-panel, as they frequently only come with one bar.
McSteve is offline   Reply With Quote
Old 05-13-2010, 08:57 AM   #7
Rewards Points: 152
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 03:23 PM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 09:49 AM
A few slightly different questions on subpanel wiring. Chris Dopp Electrical 8 06-26-2009 10:45 PM
Adding a subpanel BimmerRacer Electrical 20 04-01-2009 09:30 PM
Adding a subpanel (lots of questions) epeterson777 Electrical 20 02-15-2009 09:55 PM
