Have Fuses,old Fuse Box - Electrical - DIY Chatroom Home Improvement Forum
Old 10-24-2011, 08:53 PM   #1
have fuses,old fuse box
loss power in one room and part of kitchen. did not blow any fuses,checked all fuses at least twice.
Ed Parker is offline   Reply With Quote
Old 10-24-2011, 09:40 PM   #2
How did you check the fuses? A visual check is not always accurate.
hayewe farm is offline   Reply With Quote
Old 10-24-2011, 09:49 PM   #3
joed's Avatar
Rewards Points: 12,852
Did you check the main fuses? One of them could be out.
Old 10-24-2011, 10:31 PM   #4
liscenced electrician
Rewards Points: 538
could be a loose wire somewhere
jimmy21 is offline   Reply With Quote
Old 10-24-2011, 10:45 PM   #5
Rewards Points: 6,652
Loose leg possibly, or bad main fuse. How old is this place, and how old is the electrical system? If it is a fuse panel, not breaker, the other would be a blown fuse on the leg that is powering that half of the house. It would be the large block with the large fuses inside.
Old 10-25-2011, 12:37 AM   #6
Sfeyelectric's Avatar
Lost leg as stated above! Check your main fuse and or consider upgrading your service at this point.
Sfeyelectric is offline   Reply With Quote
big fuse problem randallatha Electrical 6 01-02-2011 11:07 AM
HVAC fuse ejconcepcion Electrical 7 01-17-2010 03:46 PM
Fuse Boxes For Showers Petrena Electrical 3 09-13-2008 01:36 AM
100 Amp Fuse - issue - HELP! Leenders Electrical 9 06-02-2008 04:06 PM
Problems with new fuse box for a dryer. needsomehelp Electrical 12 04-10-2008 11:20 PM
