Have 50 Feet Of 10/2 W/g Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 12-14-2008, 10:04 AM   #1
have 50 feet of 10/2 w/g wire
I have this new box of 10/2g and want to run a circuit into the garage for a freezer. I've been sitting on this box since 06, would be nice to use it up and not have to buy another box of 12/2 just for this.
According to the box, 10/2 looks to be overkill for my intended purpose but is it "legal" to run 110v, 15 or 20a over the 10/2?
thanks
--Mike
rsplash40 is offline   Reply With Quote
Old 12-14-2008, 10:10 AM   #2
Use it. Put on a 20A breaker. The electrons will flow more freely thru the larger wire. It will make them happy.
It will be more difficult to terminate around the terminals of the recep unless you pick up a higher grade recep with lug style terminals.
220/221 is offline   Reply With Quote
Old 12-14-2008, 10:16 AM   #3
Rewards Points: 270
Mike, not an electrician but I would not hesitate to run a lower amperage on a larger wire which will have less resistance (i think). The only worry I would have is if you try to run MORE than 15 amps on 14/2, more than 20 on 12/2. 10/2 for 15 amps is completely overkill, but should work just fine.
pcampbell is offline   Reply With Quote
Old 12-14-2008, 11:03 AM   #4
Is this going to be buried, in conduit or out in the sunlight?
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 12-14-2008, 11:15 AM   #5
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
thanks
--Mike
Is this an attached garage, if not, other rules apply here.
Yes, it is fine, I would pig tail it at the outlet junction box to 12awg to make the connection to the outlet.
The larger wire will actually reduce voltage drop and save you money, on that size run, about $3 over the next 100 years or so.
Jamie
jamiedolan is offline   Reply With Quote
Old 12-14-2008, 12:07 PM   #6
Rewards Points: 2,350
Jamie
Please elaborate...
Old 12-14-2008, 12:25 PM   #7
DIY'er
jamiedolan's Avatar
Originally Posted by InPhase277 View Post
Please elaborate...
225.30 - One supply, single disconnect for detached buildings is what I was referring to. I don't know if he has other loads in this garage, I just mentioned it in case it is detached so he would be aware of the issue.
If it is a detached garage, on the same property, you can only bring one feeder to it correct, per 225.30?
But if it is attached, then it is treated just as any other part of the home?
Jamie
Old 12-14-2008, 12:28 PM   #8
Rewards Points: 892
Jamie
What's the average resistance of a pigtail splice done correctly?
I'm wondering whether using a splice in the outlet box would negate the lower resistance of the #10 wire.
In any case, I would use the higher grade receptacle that will take #10.
I just don't like "unnecessary" splices.
Ultrarunner2017 is offline   Reply With Quote
Old 12-14-2008, 12:58 PM   #9
Thanks for the replies, it is an attached garage on a raised ranch, of course they put the panel on the far end of the house.
I bought a 20amp GFI just a little bit ago for the end, I spent the $ and got the better of the two but the screws don't seem any bigger.
Old 12-14-2008, 01:30 PM   #10
word^
Sorry....I had a ghetto moment.
BTW, #10 wire fits into the P&S GFCI's which have the lug style terminals.
Old 12-14-2008, 11:57 PM   #11
DIYer
Zero.
In reality more, but it's real close to zero.
Gigs is offline   Reply With Quote
Old 12-15-2008, 12:26 PM   #12
Rewards Points: 160
Look at the back of the GFCI receptacle. There should be holes for the wire with pressure plates that compress the wire. No need to wrap screws with GFCI recepts. Just tighten the screw with the wire in the hole. You must loosen the screw first, then insert. The #10 should fit in just fine with the compression connection. You can use a #12 pigtail if you prefer, but you must use no larger than a 20 amp breaker.
Old 12-15-2008, 01:05 PM   #13
He must use no larger that a 20 A anyway, pigtail or not
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
installing a subpanel from 10/2 wire. d_skutnik Electrical 7 10-08-2008 05:35 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
Can i add a subpanel fed by 10/2 wire? qst4sno Electrical 25 04-25-2007 05:14 AM
