Have 120 Volts With Circuit Breaker Off - Electrical - DIY Chatroom Home Improvement Forum
Old 07-02-2011, 10:19 PM   #1
Have 120 volts with circuit breaker off
I am trying to complete an addition to my home that started 2 years ago. I have gone through 3 electricians on the project and trying to finish the rest myself. I had a circuit breaker that would buzz then trip. I at first thought it was a short, but then put my wulti meter on the wire of that circuit breaker when it was off and I had 120 volts even though the breaker was off. I also had 120 volts on the neutral line for that circuit. Any thought and solutions would be greatly appreciated
justforjacks is offline   Reply With Quote
Old 07-03-2011, 06:54 AM   #2
Electrician
SD515's Avatar
Rewards Points: 504
The circuit in question is probably tied into another circuit somewhere, possibly in a receptacle/switch box, etc., in or near your addition.
Start by turning off other breakers until the voltage disappears. Then open the recpt/switch/j-boxes/lights, etc…I’ll bet you’ll find those 2 circuits tied together somewhere.
Kyle
Old 07-03-2011, 11:14 AM   #3
Licensed electrician
Rewards Points: 1,770
Would are you using to detect the voltage? Pen type non-contact detectors can give false positives.
Can't get the master circuit breaker properly seated davefoc Electrical 1 03-22-2010 06:17 AM
Circuit breaker question kupalino Electrical 6 12-18-2009 11:35 PM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 08:38 AM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
