This Has Probably Been Covered A Number Of Times Already..... - Electrical - DIY Chatroom Home Improvement Forum
Old 03-14-2011, 04:43 PM   #1
this has probably been covered a number of times already.....
I am replacing a kitchen light fixture. Coming out of the ceiling there are two white and one black wire. The new fixture has one white,one black,and one ground. Do I twist the two white wires coming out of the ceiling with the one on the new fixture?
sanman is offline   Reply With Quote
Old 03-14-2011, 04:44 PM   #2
Experienced
Jackofall1's Avatar
Yes
Old 03-14-2011, 05:48 PM   #3
Licensed electrician
Rewards Points: 996
It would be rather unusual to not have the same number of black and white conductors.
What wires was the old fixture connected to?
Old 03-14-2011, 05:55 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
I would NOT twist anything together until you get a meter to test what you have.
I also agree with Jim. There is no reason to have two whites and only one black coming from the ceiling.
Old 03-14-2011, 06:57 PM   #5
Learning by Doing
Leah Frances's Avatar
Speedy and Jim have always given me good advice.
Take a pic and give us some more specifics about the set-up. Switches etc.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-14-2011, 07:01 PM   #6
Rewards Points: 996
Thanks Leah.
I should have looked for you Sunday. I tried to go to Shore Sportsman.
Old 03-14-2011, 08:05 PM   #7
Learning by Doing
Originally Posted by Jim Port View Post
Thanks Leah.
You should have.... Sunday was a sitting on the front porch drinking a beer kind of day.... Maybe next time - shoot me a PM.
Old 03-14-2011, 09:40 PM   #8
I=E/R
a7ecorsair's Avatar
We need a day like that in MN
a7ecorsair is offline   Reply With Quote
Old 03-15-2011, 06:47 PM   #9
My bad.... I do think I need glasses What LOOKED like 2 white wires was actually a black wire with a little bit of white paint on it. So I have ONE white.....ONE black.....and ONE ground wire. I got them all connected and it works.
The Following User Says Thank You to sanman For This Useful Post:
Leah Frances (03-15-2011)
Plumbing vent was covered Bill7 Plumbing 5 01-16-2010 08:49 PM
tiling exterior covered porch with 3/4" osb subflooring nocarpenter Flooring 3 06-11-2009 04:12 PM
Post detail for raised covered deck jogr Building & Construction 3 05-16-2009 08:46 AM
Fluorescent lamp requires wall switch to be cycled several times before lighting. joejean Electrical 5 09-04-2008 09:48 AM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 01:45 PM
