Has Anybody Ever Seen Something Like This? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-27-2012, 12:44 AM   #1
Has anybody ever seen something like this?
Has anyone seen something like this?
I think my brother is trying to either electrocute the whole house/me or cause me severe confusion via electric current
I apologize for the bad pictures, they are from a video I took of the thing....it has been going on 8 months and yesterday I found this all
allsystemsgo is offline   Reply With Quote
Old 05-27-2012, 12:45 AM   #2
this pics a bit better
Old 05-27-2012, 12:52 AM   #3
Old 05-27-2012, 01:05 AM   #4
If you're asking about that little metal box with phone cord attached to it, that's just a low voltage transformer that's probably powering your doorbell or something. It has nothing to do with electrocuting you or your house. Similarly, it should not cause you severe confusion and I'm concerned as to why you hold that belief.
LooseSCruz is offline   Reply With Quote
Old 05-27-2012, 01:12 AM   #5
Sparky
Rewards Points: 510
The device attached to the box with the keyless socket is a typical doorbell transformer, the other pictures are not clear enough to make out.
Techy is offline   Reply With Quote
Old 05-27-2012, 01:37 AM   #6
The doorbell idea makes sense, but shouldn't it be closer to the doorbell? This is the basement and there are no doorbells down here...I am going to get better pics of all the wiring, sorry they suck atm. But truly thank you for your replies to this.
Old 05-27-2012, 07:31 AM   #7
Rewards Points: 1,536
The light fixture might have been the most convenient source of 120 volt power for the doorbell transformer.
Are the two cables entering the metal junction box with the transformer clamped down inside so they can't touch the sharp edges of the box holes?
Old 05-27-2012, 07:46 AM   #8
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Its a doorbell transformer, the reason it's usually located in the basement is because when roughing in, its much easier to have one wire at each door button location and chime, so the splice, is made in the basement to make it all work... thats the mess next to the panel...
I personally would have just installed the transformer at the panel, but to each his own.
Old 05-27-2012, 11:49 AM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 1,964
Shouldn't there be strain relief clamps on those Romex wires going into the metal box? Otherwise, those nice sharp edges might cut through the insulation over time.
ddawg16 is online now   Reply With Quote
Old 05-27-2012, 12:25 PM   #10
E2 Electrician
Internal clamp.
Old 05-27-2012, 12:26 PM   #11
E2 Electrician
Internal clamp is provided.
Old 05-27-2012, 01:27 PM   #12
Rewards Points: 6,652
Yep, see them all of the time. Nothing unusual about that little transformer and wire.
