Hardwired Under Cabinet Puck Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 03-10-2011, 08:01 PM   #1
Hardwired under cabinet puck lights
I am installing under cabinet lights. I like the look of puck lights and I want them hardwired to be controlled but wall switch. Walls are currently opened so I have easy access. I haven't been able to find puck lights designed for this purpose. The ones I've seen at big box stores are designed to pluginto socket and has an attached transformer/ballast. Are there any that are designed to wire into romex and wall switch, it better yet, a dimmer?
acerunner is offline   Reply With Quote
Old 03-10-2011, 08:33 PM   #2
I have seen line voltage(120v) undercab lights in the puck style at the big box stores. Now you still will need to install a box and outlet or cut off the plug and wirenut it. Switch that circuit and you should be good. Now I do remember that they looked the same in the package except for the 120v label. I worked at one before in that department. Hope that helps
Shockme is offline   Reply With Quote
Old 03-11-2011, 12:38 AM   #3
Electrical Supplier
Rewards Points: 150
To do this right you will need to do one of the following: get 120v pucks that have an integrated junction box OR (suggested get low voltage.....
There are many transformers that are hardwired and come with a junction box for the xformer. The xformers are also dimmable.
WAC makes pucks and xformers.
Pucks are the HR-88-(color) EX: HR-88-WH for white
Xformers are EN12(watts)RBAR (includes enclosure) EN12100RBAR for 100 watts
Use a LowVoltage Electronic Dimmer such as Lutrons Skylark line, SELV-300
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
LED Under Cabinet Puck Lights Go On and Off racket99 Electrical 5 01-02-2011 05:06 PM
under cabinet lights wengang1 Electrical 1 09-30-2010 04:43 PM
Under cabinet lights dismas Electrical 3 01-15-2010 03:52 PM
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 08:25 PM
