Hardwired Smoke Detector In Suspended Ceiling - Electrical - DIY Chatroom Home Improvement Forum
Old 02-17-2010, 08:59 PM   #1
Rewards Points: 640
hardwired smoke detector in suspended ceiling
Is there a correct way to install a hardwired smoke detector on a suspended ceiling? could I use a retrofit circular box and attach that to the panel then staple the line to the joist above for support? I need to get the basement detectors interconnected and the ceiling is really the only place I'd want them down there... any ideas? thanks
BlueBSH is offline   Reply With Quote
Old 02-17-2010, 09:57 PM   #2
Rewards Points: 81
If I am correct in reading what you posted why not just use a ceiling T bar bracket? They are meant to be used on drop ceilings and screw to the track. Just attach an octagon box put on a romex connector and install. U will need to cut the ceiling tile.
Chevyman30571 is offline   Reply With Quote
Old 02-17-2010, 10:46 PM   #3
I have used a piece of 3/4" plywood that spans the ceiling track! Cut a hole in the plywood for the electrical box and screw the box to the plywood!
Old 02-18-2010, 06:31 AM   #4
dSilanskas's Avatar
Simplest way is to just use a single gang old work box. Just don't over tighten the box.
dSilanskas is offline   Reply With Quote
Normal light fixtures with suspended ceiling? Scott99999 Electrical 9 09-02-2010 04:44 PM
suspended ceiling gooddog General DIY Discussions 4 10-03-2009 08:33 AM
suspended ceiling gooddog Remodeling 3 09-29-2009 09:20 PM
Suspended Ceiling Wire Protection jamiedolan Electrical 1 01-19-2009 08:56 PM
Ceiling fan suspended ceiling bdalekid Electrical 15 03-17-2007 11:03 AM
