Hardwire Undercabinet Lighting? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-21-2009, 03:37 PM   #16
I did this recently. I had standard 3 prong electrical outlets inside the cabinets. One was there for the microwave and another for the refrigerator. I plugged the puck lights into the outlets and bought a puck shaped touch sensitive dimmer switch that I put in the corner under the cabinets. Nothing can be seen at eye level, but you know where the dimmer is.
Very easy and it is to code.
TexasEd is offline   Reply With Quote
Old 04-21-2009, 03:42 PM   #17
This is what I used:
http://www.lowes.com/lowes/lkn?actio...HCL&lpage=none
Old 04-21-2009, 05:56 PM   #18
Licensed electrician
Rewards Points: 1,888
The Ambiance LV cable is not for use in the wall. You would need to use a Chapter 3 wiring method like NM-B in the walls and transition to the LV cable.
I am not sure why the inspector is ok with LV cables in the walls.
Old 04-22-2009, 12:31 AM   #19
Rewards Points: 508
Send a message via AIM to theatretch85
I just finished the rough-in for the under cabinet lighting. I bought a 500' spool of 14/2 install rated low voltage security/speaker wire and routed this to all the cabinet locations with a home run to the under-sink cabinet where I will mount the transformer(s). Total of 4 individual runs, 1 or 2 of them may have 2 lights, but otherwise it will be one light per run.
My thought is to use plug-in type transformers but I installed a 4" metal j-box with a single gang metal mud-ring so that I could attach a single gang cover plate with the 1/2" knockout and transition to flex conduit to connect a hard-wired transformer if I choose to do so, otherwise I will just install an outlet.
I did NOT drill the holes in the Sheetrock for the wires yet, but I know exactly where the wires are in the walls and left plenty of slack, I'll just drill the holes just above the bottom edge of the cabinet before I hang the cabinets and then pull the wire out of the wall. Figured this was the best idea in terms of painting and with the location of the bottom of the cabinet potentially being different.
theatretch85 is offline   Reply With Quote
Old 04-22-2009, 01:29 AM   #20
Rewards Points: 1,016
I would recommend low voltage LED puck lights... Easy to install, run cool, last a long long time.
Undercabinet lighting power source? Ideas? PDubs Electrical 7 01-28-2009 04:37 AM
Undercabinet lighting: What would you use? Karde Electrical 3 01-04-2009 10:26 AM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 12:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 08:06 AM
Undercabinet lighting spacing wbjdmd Electrical 3 11-12-2006 08:55 PM
