Hardwire Range Hood - Electrical - DIY Chatroom Home Improvement Forum
Old 02-06-2012, 03:24 PM   #1
Hardwire Range Hood
Does anyone know of any links with a good tutorial on hardwiring to an electrical outlet? I am replacing an existing hood that was a plug in with a hardwired hood. I have replaced several light fixtures, ceiling fans, switches etc., so I am comfortable doing the work, just never tied into an outlet before so I would like to do some research first. Thanks
brooksm549 is offline   Reply With Quote
Old 02-06-2012, 03:29 PM   #2
Rewards Points: 13,712
If the outlet is already there why not just add a plug to a cord and plug it in?
Old 02-06-2012, 03:38 PM   #3
I would rather have the cleaner look of not having the cord. I will be adding a backsplash so I have the ability to easily cut the wall open before hand.
Old 02-06-2012, 09:38 PM   #4
Todd Electric
If there is only one cable (romex) in the outlet that you are using for the range hood you may be able to remove the outlet box from the wall and using a proper cable connector attach that cable to the wiring compartment on the hood. If there is more than one cable, or if the one cable is too short, you will have to make a splice to extend the wire. In that case you will have to leave the outlet box accessible with a screw on faceplate. If it is only one cable and it is too short you can determine where that wire originates and replace the whole piece with a longer run allowing you to connect it directly to the hood.
Todd
todd electric is offline   Reply With Quote
Old 02-07-2012, 06:48 AM   #5
Todd
There is a black, white and red wire and it is going to be too short.
Old 02-07-2012, 03:06 PM   #6
hardwire range hood
If you can find out where that wire comes from replace the whole piece with a longer one. If you can't do that, find a place to put a junction box. You could pull the wire down to the sink base cabinet and install a junction box there with a new, longer piece of wire back up to the hood. Make sure what each of the wires (red, black and white) are used for. It would be best to look at the connections where the wire comes from. If you can't do that, use a voltage tester. Between black and white you should get approximately 120-volts. If the red is used as a ground, you should get 0-volts (maybe 1-3) between white and red and 120-volts between the black and red. If you get 0-volts or 240-volts between black and red you should have an electrician look at it.
Old 02-08-2012, 10:01 AM   #7
Leaning towards just changing the hood to a plug wire now to save the money. Do you have any suggestions of a good conversion plug/kit?
The hood I am replacing is a plug cord, do you think I can just use that cord and connect with wire nuts inside the hood?
Old 02-08-2012, 10:02 AM   #8
Julius793's Avatar
If you use a plug the circuit must be a dedicated!
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 02-09-2012, 09:43 AM   #9
It is a dedicated circuit. Any suggestions for conversion kits?
Old 02-09-2012, 09:46 AM   #10
Julius793's Avatar
Conversion kits for what?
Old 02-09-2012, 09:49 AM   #11
Licensed electrician
Rewards Points: 1,622
To allow the cord to be used on the hood.
Old 02-09-2012, 11:33 AM   #12
Yes, to swap out the hardwire and make it a plug in. The current hood is a plug in wire, my thought is to take that wire out and connet it with wire nuts to the new hood unless people think its better to use a new wire.
range hood opening is bigger than range hood jacks16 HVAC 2 06-23-2011 06:19 AM
Backdraft, Cold Air and Ice from Range Hood and Bath Fan Passion4Heels HVAC 13 08-19-2010 07:00 PM
Alternative to range hood fan Richo HVAC 2 04-11-2010 02:43 PM
Island Range Hood? fromwithin Appliances 0 11-25-2009 10:45 PM
Range hood, hardwire or receptacle? DIYGST Electrical 11 01-10-2009 06:55 AM
