Hardwire A Polarized Plug - Electrical - DIY Chatroom Home Improvement Forum
Old 10-22-2007, 10:23 PM   #1
Hardwire a polarized plug
Hi,
Need help. I bought a hanging pendent lamp that has a polarized plug to hang where an existing chandelier hangs (the chandelier is hardwire). Is it possible to hardwire the polarized plug on the hanging lamp?
Thanks for any advice.
Mrsfixit is offline   Reply With Quote
Old 10-23-2007, 03:33 PM   #2
Electrician philosopher
Probably not. UL has a problem when we cut the plugs off. That being said.....
Andy in ATL is offline   Reply With Quote
Old 10-23-2007, 04:07 PM   #3
You'll need to come up with a way to take the strain of the hanging fixture off of the wire, so the connections aren't strained. How you do that depends on the fixture that you're trying to replace.
NateHanson is offline   Reply With Quote
Old 10-23-2007, 06:24 PM   #4
Rewards Points: 150
Assuming you sort out the UL issue ... you can use a blank plate with a hole drilled out and use a strain relief grommet to attach the cable. You can get these in electronics stores like Radio Shack. I've used these grommets when building custom power supplies in the past.
slakker is offline   Reply With Quote
Avanti Electric Oven - But no Plug ? hongtea Electrical 4 03-16-2008 09:07 PM
Polarized plug light fixture- Hardwire to home electrical? timdavis3824 Electrical 3 07-09-2007 01:34 PM
Issues with appliance plug hgiljr Electrical 1 03-17-2007 08:09 AM
converting hanging light fixture to plug dukeswalker Electrical 2 09-18-2006 10:03 PM
