Hardwire LED Puck Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 07-31-2012, 01:12 PM   #1
Liz
hardwire LED puck lights
instead of solid light, they keep flashing. What's wrong?
useless is offline   Reply With Quote
Old 07-31-2012, 01:14 PM   #2
Liz
hardwire LED lights
Electrician wired these
Old 07-31-2012, 01:22 PM   #3
Too Short? Cut it Again!
Some of them are programmable to be set to flash and do other things if you want. If you hardwired them and accidentally set the function to flashing on the first in the series it would probably effect the others.
Now if they are flashing on and off at random it is probably a bad transformer or connection somewhere. Or the voltage to them is incorrect for some other reason.
If an electrician wired them what does he/she say about the problem?
Old 07-31-2012, 02:40 PM   #4
Liz
hardwire LED lights
He couldn't figure it out.
I called the company and they said i need a bigger transformer so they will send me one free!
Thanks for your help
hardwire LED puck lights useless Electrical 2 07-31-2012 01:08 PM
wiring xenon puck lights... Bagatelle Electrical 6 12-04-2011 03:05 PM
Problem: Puck lights w/ touch-sensitive switch mapsedge Electrical 1 03-14-2011 07:20 AM
LED Under Cabinet Puck Lights Go On and Off racket99 Electrical 5 01-02-2011 05:06 PM
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 08:25 PM
