Hardwire LED Puck Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 07-31-2012, 12:35 PM   #1
Liz
hardwire LED puck lights
The transformer is hardwired to 4 pucks, but they keep flashing, instead of solid light. What's wrong?
useless is offline   Reply With Quote
Old 07-31-2012, 12:40 PM   #2
" Euro " electrician
frenchelectrican's Avatar
Either you have a short or overloaded transfomer that is the two most common cuprit you will have there so the only way you can do is seperated and test one of them at time to see what causing the flashing.
Some case I see someone did used wrong trasformer as well due most LED's genrally use DC supply instead of AC supply so check that out as well.
Old 07-31-2012, 01:08 PM   #3
Master Electrician
Ac transformer is my guess. The LEDs are only firing on the positive part of the cycle.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
wiring xenon puck lights... Bagatelle Electrical 6 12-04-2011 03:05 PM
Problem: Puck lights w/ touch-sensitive switch mapsedge Electrical 1 03-14-2011 07:20 AM
Hardwired under cabinet puck lights acerunner Electrical 2 03-11-2011 12:38 AM
LED Under Cabinet Puck Lights Go On and Off racket99 Electrical 5 01-02-2011 05:06 PM
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 08:25 PM
