Hard Wiring Vanity Light Fixture Into Outlet? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-20-2013, 03:17 PM   #16
MCB
sparky
Hard Wiring vanity light fixture into outlet?
If you were redoing the bathroom anyway, I think it would have cost less than you think for an electrician to pop in and just do it right for you. They see things that you may not, from what I'm reading, there is only a few hours at the most for what is taking a week of delayed finishing...?
If you can power the outlet with the direct hot from the switch box, great, if not then it'll be switched with the light til you decide to do it right.
MCB is offline   Reply With Quote
Old 02-24-2013, 02:16 PM   #17
Rewards Points: 24
Ok so tested it today and the light works when wired from the new GFCI outlet!
A couple of questions regarding the ground though. I only have a hot and neutral coming into the outlet. The new copper wire has hot, neutral, and ground wires. The outlet has a ground screw and the light fixture has a ground screw.
I wired it the first time and didn't ground anything anywhere. When I turned the circuit on the outlet tripped. I reset it and the light came on and everything seemed fine.
So my question is...should I ground the new wire going from the outlet to the light fixture to the GFCI outlet ground screw and then ground the light fixture? Obviously a wiring newbie.
Thanks for all your help!
qwiksilvertrav is offline   Reply With Quote
confusion with track light stephenbishop Electrical 7 03-10-2012 02:37 PM
Wiring up an overhead flourescent light fixture J S Machine Electrical 13 06-03-2011 05:00 PM
Electrical bathroom vanity light fixture HEMMY1244 Electrical 4 09-29-2010 08:40 PM
Mercury Vapor Light Fixture Wiring Hoppy084 Electrical 4 06-25-2010 12:38 AM
Light fixture: Does hot&neutral designation matter, and possible wiring anomaly. Deck Electrical 8 08-26-2009 09:08 AM
