Hard Wiring Dishwasher Question - Electrical - DIY Chatroom Home Improvement Forum
Old 05-28-2010, 01:27 PM   #1
DIY Expert in Training!
Hard wiring dishwasher question
So I am nearing the end of my major kitchen renovation. I made one mistake. I placed an outlet behind the dishwasher to plug it in. Well, with a plug wired up I cannot push the dishwasher in enough. So, here is the best option I can see...
I bought a metal face plate for the outlet that you can punch out for a clamp. I was planning on using 12/2 romex into the box and connect everything inside for power. Is this ok?
gone_fishing is offline   Reply With Quote
Old 05-28-2010, 01:30 PM   #2
Licensed electrician
Rewards Points: 1,234
Why not move the receptacle into the adjaecent cabinet? Just use the existing box as a splice point.
Old 05-28-2010, 03:34 PM   #3
Civil Engineer
Rewards Points: 4,560
Why not simply hard wire the dishwasher to the box? Only issue is if you plan to move the dishwasher, but if it is a permanent install, no issue.
Daniel Holzman is online now   Reply With Quote
Old 05-28-2010, 05:16 PM   #4
Sparkaholic
Rewards Points: 150
Send a message via Yahoo to sparks1up
If you hardwire the dishwasher you need to install a breaker lockout device on the breaker that feeds it! Your cord and plug is your means of disconnect.
Jims suggestion above is a better solution!
Answers based on the mood I am in when you ask!
sparks1up is offline   Reply With Quote
Old 05-30-2010, 05:58 AM   #5
dSilanskas's Avatar
Code reference please
dSilanskas is offline   Reply With Quote
Old 05-30-2010, 09:25 AM   #6
Sparkaholic
Rewards Points: 150
Appliances are required to have a means of disconnect. For dishwashers, you have a few options.
Some dishwashers will qualify under section 422.34 if the unit switch has a marked-off position and opens all ungrounded conductors.
Dishwashers are permitted to be cord-and-plug connected per section 422.16(B)(2) and section 422.33(A) permits this connection to serve as the disconnecting means.
422.31(B) provides a third disconnecting option. This allows the branch circuit breaker to serve as the disconnecting means if it is within sight of the appliance or can be locked in the open position.
Old 05-30-2010, 11:48 AM   #7
Rewards Points: 530
One of circuit protectors for my computers has a swivel plug that plugs into the wall. Lets it fit very close to the wall/rec. Maybe you could use one of these flush plugs.
Old 05-30-2010, 04:48 PM   #8
dSilanskas's Avatar
Key words CAN BE LOCKED doesn't mean that it has to be locked. No one locks a breaker in the on position around here kinda silly if you ask me
Old 05-30-2010, 04:57 PM   #9
Sparkaholic
Rewards Points: 150
Its a lock off not a lock on! It is so you can lock out the circuit from being energized while you're working on it! Read it right! If that is really how you read that I think you're going to fail your inspection!
Old 05-30-2010, 10:24 PM   #10
dSilanskas's Avatar
You wont fail your inspection I promise you that. I've wired D.W. direct for many many years and you don't need anything special.
Old 05-30-2010, 11:16 PM   #11
I've yet to see any DW with a switch around here
One part of that section states breaker serves as the disconnect if not over 300v...1/8hp
*edit* not over 300va....not 300v
Old 05-30-2010, 11:58 PM   #12
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
there are a lot of breakers that get locked on. One in particular are circuits for fire alarms. Many places reqqurie they be locked on
but that doesn't have anything to do with this. The dishwasher breaker needs to be able to be locked OFF.
and I have had an inspector check to be sure the breaker is lockable. I would think he would have failed the inspection if it were not.
Old 05-31-2010, 12:04 AM   #13
nap
You talking to me?
nap's Avatar
check for appliances over 300 Va 1/8 hp. 422.21(B) and then check your dishwasher. 300 va is only 2.5 amps at 120 VAC.
breaker can be used but must be lockable. Locking mechanism must remain in place whether being used (at the moment) or not.
Old 05-31-2010, 09:33 AM   #14
Ahhh..va - missed that somehow
Yeah that changes things
Isn't a 40a/50a hard wired stove an appliance ?
So that should mean hardwired stoves & appliances also need lockouts on the breaker ?
I still think with an appliance Off is Off...no need for another disconnect in a residential setting
422.34 states that if the control has an OFF position then switch is not needed
Stoves & dishwashers have an OFF position
So for one family (C) applies - breaker is OK
Old 05-31-2010, 09:42 AM   #15
Master Electrician
Rewards Points: 3,746
Nap, just my observation, the inspectors we deal with in Berrien County, MI do not enforce this for residential installs.
brric is offline   Reply With Quote
Question about series wiring. Chevyman30571 Electrical 7 02-26-2010 09:54 AM
Electrical Box Wiring Question OmahaGirl Electrical 9 02-18-2010 09:03 AM
carrier 48ss-042 wiring Question bekind42 HVAC 3 06-15-2009 06:54 PM
Series wiring question. ingeborgdot Home Theater 2 05-29-2009 10:01 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
