Hard Wireing A Stove/oven - Electrical - DIY Chatroom Home Improvement Forum
Old 11-18-2010, 03:02 PM   #1
Hard wireing a stove/oven
I have an old house. I am remodeling my kitchen and am putting in an oven. The old oven was directly wired and the issue I am having is there is 4 wires coming out of my oven and only 3 from the circuit box. Black,Red,White,Green are coming from my oven and Black, Red, Ground coming from my circuit box.
Not sure where to put the whit neutral wire. Green to ground I guess, black to black and red to red. But not sure about the white neutral. can anyone help?
javajunkie is offline   Reply With Quote
Old 11-18-2010, 03:11 PM   #2
Licensed electrician
Rewards Points: 1,622
The instructions should show you how to convert the oven to 3 wire operation. Most times a bond strap change is involved.
Old 11-18-2010, 03:16 PM   #3
My sister gave me her oven because she changed out hers in her new house. There are no instructions and I'm not sure what a bond strap is?
Old 11-18-2010, 07:39 PM   #4
" Euro " electrician
frenchelectrican's Avatar
The bond strap is a thin copper ribbon which it will connect between the netural and appalicne frame.
Merci.
Marc
faucet hard to pull out? Leprichon Plumbing 14 11-15-2014 12:11 PM
How hard is your water? How deep is your well? brokenknee General DIY Discussions 10 05-05-2009 07:17 PM
Hard drive redline PC Repairs & Upgrades 14 03-06-2009 04:27 PM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 06:11 PM
hard metal vs. flexible ducts katea HVAC 4 05-18-2008 08:23 AM
