Old 12-01-2010, 12:06 AM   #1
Hard wired smoke detectors
HELLO; I am about to wire 9 smoke detectors in different rooms.
I make a connection to a junction box in the attic, and start
the run from there.
First smoke detector is connected black to black with a pigtail
to the detector; white to white; ground to ground with a
pigtail to the detector box.
The second smoke detector is a different set-up:
The instructions say: connect red wire to the interconnect
wire from the detector which is usually yellow.
QUESTION: Why do we continue now with red wire?
Was not there the black hot wire to connect all detectors
in series? Is it right to connect red wire to yellow wire?
WHY this extra red wire?
I APPRECIATE ANY ADVICE THANKS.
Gabriel24 is offline   Reply With Quote
Old 12-01-2010, 12:09 AM   #2
The red wire is used to set off all the other detectors in the event that one of the detectors goes off.
Steelhead is offline   Reply With Quote
Old 12-01-2010, 12:41 AM   #3
yes,the red connects to yellow.when the detector goes off,low voltage(about 9 volts) is put on red wire (yellow wire)to set off the rest of the detectors.
oleguy74 is offline   Reply With Quote
Old 12-01-2010, 01:12 AM   #4
The red wire can be red, yellow or orange. There should have been instructions on how to wire the smokes. The instructions should also tell you how many can wired together. If you did not get instructions, they may be available on line.
fireguy is offline   Reply With Quote
Old 12-01-2010, 09:02 AM   #5
Are you aware that you need to use a three wire from the first detector to all of the rest of the boxes to provide an interconnect? The power comes in on a two wire cable (black and white). You then run a three wire cable (black, red, and white) from the first box to the next box and continue running three wire cable to the rest of the boxes for the remaining smoke detectors. The first detector hooks up as you said with the yellow connected to the red wire. From there on out you connect the rest of the yellow wires for the other detectors to the red wire.
teamo is offline   Reply With Quote
Smoke Detectors for Bedroom cibula11 Electrical 4 09-14-2009 01:21 AM
CO and Smoke Detectors Chemist1961 HVAC 20 01-22-2009 07:43 PM
Smoke Detector, Intermittent Chirping Rod Electrical 18 02-23-2008 07:46 PM
Wired Smoke Detectors? bjstewa Electrical 2 05-09-2007 09:20 AM
Hard wired fire alarms keeping going off sdgoss Electrical 6 11-09-2005 09:57 PM
