Hard Wire Or Not To Hard Wire Into Switch Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 02-07-2013, 02:48 PM   #1
Hard wire or not to hard wire into switch heater
I'm getting my furnace replaced and I been hearing about getting it hard wired into a switch instead of an outlet. Some have said its necessary and others have to protect the warranty from the manufacturer. One even said he didnt and kept blowing thermal coupler and he thinks its because of that...Any ideas on this
GRed is offline   Reply With Quote
Old 02-07-2013, 02:57 PM   #2
Licensed electrician
Rewards Points: 1,018
Furnaces are not listed for use with a flexible cord. I have never seen one not hardwired.
A service switch is needed to kill the power while the unit is serviced.
Old 02-07-2013, 03:01 PM   #3
Hard wired
Not anymore mine is over 30 yrs old I know it needs to be piped out of the unit. Then it can be flex with a drip leg...I'm referring to the outlet it generally is plugged into..does that need to be hard wired Into a switch to turn off and on when not in use.
Old 02-07-2013, 03:05 PM   #4
MarginallyQualified
Rewards Points: 2,464
Originally Posted by GRed View Post
Not anymore.
Oh.
Be sure to come back and tell us how it turns out.
Old 02-07-2013, 04:34 PM   #5
Furnaces should not be plugged into receptacles. Are you saying yours was or is?
Old 02-07-2013, 06:13 PM   #6
Rewards Points: 1,418
Blowing the thermocouple has nothing to do with the way the furnace is wired.
Permanent or fixed installations of equipment should not use cords and plugs and receptacles for the electrical connection.
If you wish to power the furnace using a generator connected via extension cord, use a double pole double throw switch for the service switch with the common terminals connected to the furnace lead (hot and neutral) and one traveler terminal group connected to the power feed (hot and neutral). Connect the other traveler terminal group to line going to a male receptacle. The extension cord from the generator is plugged on here.
Old 02-07-2013, 06:21 PM   #7
furnace
yes my furnace is over 30 yrs on and it was plugged in to an outlet. are you saying its required to have a switch?Hard wire or not to hard wire into switch heater-dsc_0111.jpg
gold flex coming out of the unit.. now it has to be hard piped in then flex from that point with a drip leg. the reason im asking is Im planning to do this myself..and selling our house and dont want a buyer to have to negotiate against it, however, once I do it what are the chances of a buyer asking for a city inspection vs a home inspection, i just talked with a realtor and she said once they see a new furnace they will ask for a city inspection.. I thought...hmmmm im not soo sure about that. I asked the same realtor if I dont change it out what would the inspector say and she said as long as its functional and running it will pass... hmm to me that kinda contradicts what she said previously. what are your thoughts am I wrong?
Old 02-07-2013, 06:30 PM   #8
MarginallyQualified
Even 30 years ago it was.
Old 02-07-2013, 07:05 PM   #9
Oso954's Avatar
Rewards Points: 420
I don' know whether it is a local code amendment or perhaps a different definition of furnace. But it is quite common (here) for a central heating (forced air) gas "heater" to come with an appliance cord. They are plugged into a fused outlet. Pull the plug to service the unit.
Oso954 is online now   Reply With Quote
The Following 2 Users Say Thank You to Oso954 For This Useful Post:
brric (02-07-2013), mpoulton (02-07-2013)
Old 02-07-2013, 07:10 PM   #10
Semi-Pro Electro-Geek
Rewards Points: 2,856
When I was a kid in Vermont, the furnaces in both houses we lived in were plugged into fused receptacle/switch combo devices mounted next to the furnace. I think I remember that from a house in Nebraska when I was much younger, too.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 02-07-2013, 07:15 PM   #11
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Unless there is a local amendment, or the furnace is listed to be cord and plug connected, it is not legal to cord connect a furnace.
The Following User Says Thank You to k_buz For This Useful Post:
Oso954 (02-07-2013)
Old 02-07-2013, 07:59 PM   #12
Engineer
Rewards Points: 161
I've searched on this issue myself in previous years, and there always seems to be an argument between folks in the business. Seems there are inspectors that pass it, and those that won't. I'd venture to guess it's not allowed, but I'm now hearing of areas around the country where it seems to be standard practice (parts of Louisiana, and California are ones I've heard recently.)
When it comes to generator use, I've always thought that a cord and plug solution beats a suicide cord (or any other hack job a homeowner can do.) After all, one of the main reasons homeowners try to backfeed their home is for the furnace.
diystephen is offline   Reply With Quote
Old 02-07-2013, 08:41 PM   #13
Missouri Bound's Avatar
I find that very unlikely. All central funaces need to be hardwired and should have a disconnect at the furnace location. Code does not permit plugging it in. Portable heaters are another story.
Do you want it your way or the right way?
Old 02-07-2013, 09:54 PM   #14
Electrical Enthusiast
Rewards Points: 504
In my area, regular 120V natural gas furnaces are almost always plugged into a dedicated outlet with a flexible appliance cord, not hard-wired. They pass inspection too.
Kyle_in_rure is offline   Reply With Quote
Old 02-07-2013, 09:58 PM   #15
Kyle, where is here?
Help wiring for double switch - and why the hot white wire? BusterT Electrical 4 10-20-2012 01:37 PM
Adding a wall switch but found a random "hot" blue wire crzycicada Electrical 8 10-13-2012 06:17 PM
Wire gauge for water heater and rewiring poesprogeny Electrical 15 11-18-2011 07:22 AM
Radiant heater thermostat switch wiring question tumblinman Electrical 12 07-11-2011 11:05 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
