Old 10-03-2008, 08:18 PM   #1
Hard Time Trying To Wire 4 Switches
Hi everyone i'm having a hard time trying to wire 4 switches to control 2 light, i have bought and found a couple of books but none explain how to wire such a cuircut . Right now i have i have 4 3-way switches but no look so if anyone has any suggestion please help!
tony
kenny357 is offline   Reply With Quote
Old 10-03-2008, 09:02 PM   #2
Electrician
SD515's Avatar
2 switches controlling a load is a 3-way circuit. 3 or more switches controlling a load is a 4-way circuit.
In your case, you need two 3-way switches, and two 4-way switches. One 3-way sw goes at the beginning of the 'run' and will have power enter and start the switch leg. The other 3-way will be at the end of the 'run', and the load will connect to it. The 2 4-way switches go between the 3-ways. Let us know how you have your circuit set up...what wires you have pulled, which box the source (supplying power) enters and which box the load enters.
Kyle
Old 10-04-2008, 11:44 AM   #3
joed's Avatar
You need two 3way switches and two 4 way switches. Tell us how you cabled this and I will draw you a diagram. Do NOT attempt to put two fixture between the switches.
Bonding (bond wire) & Spa Installation on existing concrete pad crusius2 Electrical 1 11-14-2007 01:00 PM
compressor... to hard wire crecore Electrical 3 11-10-2007 01:02 PM
I really need help! POOK Electrical 34 04-20-2007 08:01 PM
ok to leave chandelier third wire unconnected? gonzales9 Electrical 5 01-12-2006 09:10 PM
Hard time with contractor jaskoo Building & Construction 10 11-30-2005 07:07 AM
