Hanging Light J Box Too Close To Joist - Electrical - DIY Chatroom Home Improvement Forum
Old 12-29-2009, 02:28 PM   #1
Rewards Points: 270
Hanging light J box too close to joist
I drilled a 1/8" pilot hole for a 4" circle j box for a hanging lamp. It is about 1" away from the joist. The hole I drilled is perfectly centered in front of a window, with not much room for moving it around without looking weird. Is there some sort of option I have here?
pcampbell is offline   Reply With Quote
Old 12-29-2009, 02:48 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
You could use a pancake box and secure it right to the underside of the joist.
wirenut1110 is offline   Reply With Quote
Old 12-29-2009, 03:29 PM   #3
Rewards Points: 270
thanks, that looks like it'll work.
Old 12-29-2009, 10:51 PM   #4
Registered User
Rewards Points: 526
Don't forget to ground the metal pancake box. I've seen 3 different times electricians get caught by an inspector for that...
Be safe, Gary
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
Adding a light to an existing 3-way connection nthomp16 Electrical 2 07-21-2008 06:57 PM
Cutting/drilling hole in joist - How big? curls00 Carpentry 3 07-20-2007 09:56 PM
converting hanging light fixture to plug dukeswalker Electrical 2 09-18-2006 09:03 PM
