Hanging Light Fixture; Wire Twists As Chain Tightened - Electrical - DIY Chatroom Home Improvement Forum
Old 11-21-2012, 10:40 AM   #1
Rewards Points: 83
hanging light fixture; wire twists as chain tightened
Hi,
Just curious if anyone knows a trick to this. Ive got a hanging light fixture Im changing out with a new one. The old one, installed by a pro, has the wire " meander" nicely up the links thru the screw collar and into the ceiling.
The other room I replaced I had much trouble when screwing the screw collar into the bracket. I need to turn the screw collar to tighten it into the bracket in the box. This turns, or spins the connected chain, but the wires in the box ( obviously ) do not turn, so the wire weaved thru the chain starts twisting and looking, um."ugly" for lack of a better term.
Is there a better way I am not seeing?
thanks!
D270 is offline   Reply With Quote
Old 11-21-2012, 10:46 AM   #2
Rewards Points: 13,472
Got a picture?
No idea what your talking about with that description and terms.
Old 11-21-2012, 11:01 AM   #3
Rewards Points: 1,192
Don't connect your wires until last. Do a dry run of your canopy fit before you connect wires .
bobelectric is offline   Reply With Quote
The Following User Says Thank You to bobelectric For This Useful Post:
brric (11-21-2012)
Old 11-21-2012, 11:04 AM   #4
joed's Avatar
Rewards Points: 12,464
Twist the opposite way before you install. Then the install will untwist them.
Old 11-21-2012, 11:08 AM   #5
Rewards Points: 83
Sorry, I had to reduce the pictures so I could upload them, thank-you for the quick responses. Hopefully this helps describe what I am talking about.
I put the bracket in the box, and then I take the screw collar close to the box, attach the wires and stuff them into the box.
Then this is where I have trouble. As I screw in the screw collar which is attached to the chain, everything turns except the wires in the box. The wires in the box twist as does the wire through the chain.
Edit: Twisting the wires opposite way sounds good (smacking forehead). Thanks.
hanging light fixture; wire twists as chain tightened-untitled-1.jpg   hanging light fixture; wire twists as chain tightened-untitled-3.jpg   hanging light fixture; wire twists as chain tightened-untitled-4.jpg   hanging light fixture; wire twists as chain tightened-untitled-5.jpg
Removing old light fixture & install ceiling fan sjk Electrical 3 04-17-2011 08:32 AM
wirinig new light fixture to old wire michael74 Electrical 6 02-26-2011 09:52 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 09:44 PM
converting hanging light fixture to plug dukeswalker Electrical 2 09-18-2006 09:03 PM
