Old 09-27-2012, 12:17 PM   #1
hanging light fixture, black, YELLOW, ORANGE?
Hi,
My newer home in chicago never has the colors I expect in the boxes.
So I have a ceiling box to hang a simple 2 wire fixture plus a bare copper ground to the box which has black-hot- then my confusion, yellow and orange is in there too.....neither of which seems hot no matter what combo of switches in the house I use. I have a double switch in this room, and one switch is for the outlet I believe.
Aren't orange and yellow for 480VAC, just regurgitatin what an internet search came with for standard color use.
I am guessing I will cap the orange or yellow and wire black and the other to the 2 wire lamp....2 wires shouldn't matter....just needs to go and on, right?
bergerdude is offline   Reply With Quote
Old 09-27-2012, 01:18 PM   #2
I think I'd start by taking the cover off your double switch, and see if there are any yellow or orange wires in there. Might be a clue as to what is going on.
Dave632 is offline   Reply With Quote
Old 09-27-2012, 01:40 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Due you are in Chicago they have uquine wiring colour format so let me post this real quick.,
White-Neutral
Grey-Dedicated neutral for GFCI
red-black -blue--Power
Brown--travelers for three way
purple--GFCI protected power
yellow-orange---switch legs
This is typical but be aware there may be some change along the way but this listing will typically cover most case beside the AFCI which I have not check it out yet.
Merci,
Marc
frenchelectrican is online now   Reply With Quote
The Following User Says Thank You to frenchelectrican For This Useful Post:
mpoulton (09-27-2012)
Old 09-27-2012, 07:19 PM   #4
Semi-Pro Electro-Geek
White-Neutral
Merci,
Marc
As unnecessary and crazy at most of Chicago's rules are, this is a very useful standard. It's pretty cool to have that kind of predictability and identifiability in an electrical installation. Most commercial jobs elsewhere don't even have that.
mpoulton is offline   Reply With Quote
new light fixture won't work after having worked fine initially docchanka Electrical 17 08-29-2011 09:07 PM
HELP! Wiring 2 switches with new light fixture michugana Electrical 7 04-10-2011 07:49 PM
Ceiling Light Fixture Yellow Material df002f Electrical 3 01-12-2011 02:51 PM
converting hanging light fixture to plug dukeswalker Electrical 2 09-18-2006 10:03 PM
Changing Light Fixture - Way too many wires and light wont switch off marapapa Electrical 3 01-13-2006 02:16 PM
