Hanging Chandelier/Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 09-09-2012, 12:50 PM   #1
I am looking to replace the current light fixture in my dining room with a chandelier. Currently, the current fixture has 2 bulbs with a set of wiring per bulb. The chandelier only needs one set of wiring from the ceiling (excuse my lack of terminology as I am fairly new homeowner). Please let me know how to proceed to hook up the lighting. (confused because there are 2 sets of wiring while the chandelier only needs one)
Thanks.
phillysfinest4 is offline   Reply With Quote
Old 09-09-2012, 01:07 PM   #2
Licensed electrician
Rewards Points: 1,872
You would have a black and a white from each bulb socket. If you only have one socket you connect them to the same wiring as the old fixture.
Old 09-09-2012, 01:23 PM   #3
So since the chandelier only requires one set of wiring, I don't tie off the second set coming from the ceiling?
Not quite following, thanks
Old 09-09-2012, 01:31 PM   #4
You connect the new fixture to the same wires as the old fixture.
Old 09-09-2012, 01:39 PM   #5
Thank you. That answers half my questions, the other half if the old fixture has wiring for 2 bulbs coming from the ceiling, the new chandelier only only needs one set of that wiring.
Old 09-09-2012, 02:54 PM   #6
The ceiling wiring does not change regardless of the number of sockets on the fixture.
Old 09-09-2012, 03:18 PM   #7
ok cool, thanks, will I need a mounting bracket or does what comes standard with the chandelier enough?
thanks
Old 09-09-2012, 11:13 PM   #8
" Euro " electrician
frenchelectrican's Avatar
thanks
Most case the new chandelier useally come with mounting bracket however there one part you may want to pay attetion to is the junction box due some chandelier can get pretty heavy with weight so make sure the junction box is very soild mounted ( a ceiling fan rated box work the best for this purpose ) otherwise follow the instruction on the chandlier to mounted properly.
Merci,
Marc
Old 09-10-2012, 06:54 AM   #9
Thank you
Old 09-10-2012, 06:43 PM   #10
Rewards Points: 115
you refer to two sets of wires from the ceiling. did the old fixture have two switches? were the two sets of wires spliced together? or were there two sets of loose wires?
pokey is offline   Reply With Quote
Old 09-10-2012, 07:30 PM   #11
It had one switch. From the ceiling there are 2 sets of wires, 1 set of 2 to each light bulb. So 4 total wires coming out of the ceiling. The chandelier only requires one set of wires, only 2 total wires. That leaves me with another set of wires with no need for. What do I do with them? 2sets of loose wires
Old 09-10-2012, 08:51 PM   #12
dmxtothemax's Avatar
Rewards Points: 5,600
Originally Posted by pokey View Post
you refer to two sets of wires from the ceiling. Did the old fixture have two switches? Were the two sets of wires spliced together? Or were there two sets of loose wires?
please refer to reply #6.
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
phillysfinest4 (09-10-2012)
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 09:50 AM
Free Hanging Stairs mikelscrole Carpentry 4 06-10-2012 09:36 AM
Hanging Drywall in an attic Graye2 Drywall & Plaster 1 02-07-2011 06:42 AM
Hanging a Heavy Mirror frapha1 General DIY Discussions 6 01-03-2010 11:21 AM
