Hanging Chandelier Directly To Exposed Wood Beam - Electrical - DIY Chatroom Home Improvement Forum
Old 02-02-2010, 07:35 PM   #1
Hanging Chandelier directly to exposed wood beam
Hi. I recently bought a home where the last residents took the ceiling fan that was installed over the dining room table. I would like to hang a small chandelier and I don't think I would have a problem doing so except for one issue. The electrical wire is hanging down directly out of a 3.25" beam that is going across the ceiling and it looks like the previous owner just attached the ceiling fan directly to the wood. I guess my question is how bad is it to install a chandelier directly to an exposed wood beam without using a ceiling outlet box? I figure I can screw the chandelier directly into the beam and tuck the wires into the canopy. I am sure it is not advisable but I see no other way. Do you see any other way? I attached two pictures to give you a clear idea of what I'm talking about.
Hanging Chandelier directly to exposed wood beam-pic1.jpg   Hanging Chandelier directly to exposed wood beam-pic2.jpg
tim92887 is offline   Reply With Quote
Old 02-02-2010, 07:54 PM   #2
Rewards Points: 162
To be legal, you need a box mounted to the bottom of the beam. You could probably get away with a round 1/2" pancake box. Spray paint the box to match the finish of your fixture.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 02-02-2010, 09:34 PM   #3
Registered User
Termite's Avatar
Although there's technically a possible issue with box fill, I think a pancake box SECURELY fastened to the beam would be a heck of a lot better than what you've got now.....Which is just plain dangerous. Connections need to be made in a box!
Old 02-02-2010, 09:42 PM   #4
I tried to find one showing it attached to the ceiling
I'd go with metal over the plastic
Old 02-02-2010, 09:45 PM   #5
Military Mom of 4
Snav's Avatar
and the box should be properly insulated - no wire connections should ever contact wood.
Last year I took down an old light fixture in the laundryroom - and the ceiling was charred where there was a wire short. . . eep!
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 02-02-2010, 09:50 PM   #6
Registered User
Termite's Avatar
A simple plastic grommet is the only additional device necessary/required. It'll insulate the romex from the edges of the box knockout and will secure the wire in place. As mentioned, the wire connections must not occur in the beam, they must be in the box.
Old 02-03-2010, 01:39 AM   #7
Thank you all for replying. I did not know they made such slim boxes like that and I think that will actually work out perfectly. THanks again!
Old 02-03-2010, 07:35 AM   #8
Military Mom of 4
Snav's Avatar
How "tall" is the item you're installing? If you drop it down 12" would it be too low?
If the item is small and an extra 6" or 12" is ok - your alternative could be a short or long pipe setup - often used to hang lighting from peaked or tall ceilings. (It's just a hollow tube - it attaches to your ceiling or stud at the top and the other end has brackets on it to attach your light/fan directly to it. You then run your wires up through the pipe - no one's the wiser).
They make them for ceiling fans and for light fixtures.
Old 02-04-2010, 09:42 PM   #9
all done
Can't really do the pole idea as I needed to loop the chain to a hook because the hole with the electrical wire was not centered. Anyways the pancake outlet box worked great. The canopy of the chandelier actually covered almost all the outlet box so there was no need to paint it. Heres how it came out. Thanks again.
Hanging Chandelier directly to exposed wood beam-photo3.jpg   Hanging Chandelier directly to exposed wood beam-photo4.jpg
Old 02-05-2010, 07:53 AM   #10
Military Mom of 4
Snav's Avatar
Cool deal . . . you got to it quick. (I'm usually all talk and then procrastinate
Old 02-05-2010, 09:33 AM   #11
Nice fix, I really like that ceiling
Old 02-05-2010, 09:33 AM   #12
Rewards Points: 502
Nicely done, and safe!
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Rafter to ridge beam height JESSBRA2 Building & Construction 1 10-20-2008 03:34 PM
Hanging drywall basement ceiling from engineered wood I-beam joists ja_trusty Building & Construction 6 10-09-2008 11:06 AM
Mounting a light to a beam steve1234 Electrical 1 10-19-2007 02:06 PM
Hanging a beam/rafter from a beam snmhanson Building & Construction 4 01-11-2007 10:37 PM
