Handy Tester For New Owners - Electrical - DIY Chatroom Home Improvement Forum
Old 06-28-2013, 03:13 AM   #1
biggles's Avatar
handy tester for new owners
might consider picking up one or similar from Harbor Freight great for volts/amps,and ringing out wires and switches .hang it on a nail above the work bench for those midnight runs.item #96308
Old 06-28-2013, 03:20 AM   #2
biggles's Avatar
and a multimeter to back it up won't break the bank either#37772
Old 06-28-2013, 07:02 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
The top one is all the multi-meter most folks will ever need. Although I'd spend a few more dollars and get a decent one.
Old 06-28-2013, 10:01 AM   #4
Rewards Points: 160
I bought a cheap Triplet clamp meter and I cannot trust the current readings.
With no current flowing, the meter shows about 2-3 amps that are not present. (no ac adjustment)
POS, IMO
Spent over $100 on it.
Should have coughed up another $200 and got a good Fluke clamp.
Old 08-01-2013, 01:50 AM   #5
Rewards Points: 452
Is this one good enough for basic electrical testing around the house?
They give these out for free all the time.
pman6 is offline   Reply With Quote
Old 08-01-2013, 03:23 AM   #6
Rewards Points: 1,192
I did buy the ammeter shown from H.F. Compared amp readings to 2 different amprobe meters and all were the same where I liked it,until I dropped it.Lost the display.
bobelectric is offline   Reply With Quote
Old 08-01-2013, 01:10 PM   #7
Rewards Points: 5,974
I am not a Craftsman guy but I will say I have really been pleased with their multimeter. When it comes to electric I would NEVER trust a Harbor Freight unit.
Old 08-01-2013, 01:20 PM   #8
joed's Avatar
Rewards Points: 12,862
Who gives them out for free and where can I get one?
Old 08-01-2013, 04:12 PM   #9
Rewards Points: 452
harbor freight. they give out coupons all the time.
Old 08-01-2013, 04:20 PM   #10
MarginallyQualified
Rewards Points: 2,464
get analog.
Old 08-01-2013, 06:56 PM   #11
Bigplanz's Avatar
Rewards Points: 990
I have a half dozen of those free meters. They all work. I have one in each tool box. I have one of their amp meters and was accurate when i was trouble shooting a dryer issue.
Bigplanz is offline   Reply With Quote
Old 08-01-2013, 08:29 PM   #12
Rewards Points: 4,796
I buy Harbor Freight tools all the time. They are so cheap that I don't mind if one occasionally breaks or doesn't work quite right. The stuff that does work more than makes up for that.
I don't have a problem with a cheap multimeter. However, when it comes to using a tester to see if there is voltage present before working on the wires, I would highly recommend something better and more reliable than a Harbor Freight tool. It's too risky.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
ToolSeeker (08-02-2013)
Old 08-01-2013, 08:33 PM   #13
Rewards Points: 1,016
http://www.lowes.com/pd_205783-72068-TK-30_0__
____________
Vince
Old 08-02-2013, 05:53 PM   #14
Rewards Points: 452
I just got the free HF multimeter, and in the instruction sheet, it says not to use it in circuits higher than 10 amps. All the circuit breakers are either 15 or 20 amps
so that means I can't test an electrical box for ground connection?
The Following User Says Thank You to pman6 For This Useful Post:
oh'mike (08-02-2013)
Old 08-02-2013, 08:51 PM   #15
10a limitation is likey speaking only to when using to measure current with the meter in series with the circuit.
____________
Vince
The Following User Says Thank You to vsheetz For This Useful Post:
MTN REMODEL LLC (08-02-2013)
Electrical Newbie - Voltage Tester has "O" "L" "H" Settings - Not sure if wire is hot splendorlex Electrical 15 11-22-2014 06:59 AM
Need to buy good value compression tester for a DIY'er- Suggestions? amodoko Automotive Repairs 4 02-11-2013 10:22 AM
there is power according to the tester, but no power when you plug in the lamp? Beckiec4 Electrical 6 10-20-2012 07:39 PM
Need recommendation of non-contact voltage tester miamicuse Electrical 6 05-22-2012 04:33 PM
Non-contact tester trips but multimeter reads 0 volts paladin-x Electrical 11 02-02-2012 12:07 AM
