Handling Old Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 10-13-2008, 08:32 AM   #1
Rewards Points: 342
Question
Handling old wiring
I am redoing parts of my bathroom (40 year old house) and occasionally I need to move electrical wires out of the way and them put them back. Are wires of this age brittle or are they malleable enough to move around without too many problems? If I need to pull the old staples should I use a new staple when putting the wire back? Do I need to use caution when inserting the staple on the old wire?
tripower is offline   Reply With Quote
Old 10-13-2008, 10:08 AM   #2
Rewards Points: 240
Yes, Yes and Yes.
Old 10-13-2008, 10:35 AM   #3
Old wires can be especially brittle near light fixtures. Years of high heat can make the insulation so it just crumbles with any movement. Best to replace this wire if you have the walls torn apart.
Billy_Bob is offline   Reply With Quote
Old 10-13-2008, 10:45 AM   #4
Id replace it, bring your bath up to code with a 20 amp ded. for a gfci.
Remember, your not supposed to modify ungrounded circuits.
rgsgww is offline   Reply With Quote
Old 10-13-2008, 08:03 PM   #5
joed's Avatar
Rewards Points: 13,718
If it is not a 20 amp bathroom dedicated circuit then I would replace it to meet current code while the wall is open. Since the wall is open it may even be required.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
1939 House Wiring upgrade jimmyfloyd Electrical 4 10-01-2008 03:56 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
