Halogen Track Lighting Quit Working - Electrical - DIY Chatroom Home Improvement Forum
Old 02-06-2010, 11:56 AM   #1
Halogen track lighting quit working
I installed the halogen track lighting a few months ago and it worked fine except a couple of bulbs went out. I replaced them with 50W instead of the recommended 20W max. So I had 160W going on a track that was supposed to have 150W max. That worked OK for a few weeks, then the whole thing went out.
I tightened everything, replaced the 50W bulbs with 20W bulbs so I had 100W going on the track rated for 150W. The lights would go on, but quickly the whole thing would go out. I figured it was the transformer.
Installed a new transformer of exactly the same brand and specs: Lightech LET-151. 120V input, 12V output. Lights went on for a couple of seconds, then out again.
The Lightech transformer has an "auto-reset," so there is no reset button on it. It seems the only time it resets is when I disconnect it from the power source and reconnect it.
Not sure what to do next.
Dialogdog is offline   Reply With Quote
Old 02-06-2010, 01:00 PM   #2
Too Short? Cut it Again!
Make sure the hot connection to the track and end cap are both fully inserted and tight and are engaging the track. Sometimes they work loose.
Old 02-06-2010, 01:02 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
You are obviously a DIYer that has just learned a valuable lesson and made a DIY attempt that sounds logical to recover. What do your meter readings tell you?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-08-2010, 08:57 PM   #4
Thanks PaliBob and sdester
I think I've narrowed it to a grounding issue. The canopy cover is loose and I can't figure out how to tighten it. There's some kind of insulating washer around the central metal piece to which the ground wire is attached and through which the hot wire runs. The looseness is around that washer.
With everything connected and tightened up, I get a 12 volt reading only when I touch one lead to the contact at the rail and the other poking around that loose insulator/washer and the metal canopy.
I will keep trying to figure out how to assemble/disassemble this piece until I break it. Meantime, I have an email into the manufacturer, Alfa.
Old 02-08-2010, 09:20 PM   #5
Lightbulb
A good (and basic) suggestion; Re-read the original assembly/installation instructions. Or get on the Mfr.'s website and get the assembly & parts list from there. Also, with the power off. You could run a continuity test on all the Grounding and power supply parts.!
p.s: Don't overload the sockets or the transformer & track by inserting higher wattage bulbs than recommended. It could burn out the transformer or any other part of the track assembly!
spark plug is offline   Reply With Quote
Tags
halogen , lighting , transformer
Customized track lighting? CheshireFool Electrical 3 02-03-2010 03:37 AM
Dimmer for Halogen Track Lighting CompEngineer Electrical 2 12-04-2009 05:20 AM
Track Lighting Installation - No Electricty tazmajazz Electrical 11 10-19-2009 10:09 AM
LED track lighting feasible yet? GFW Electrical 8 01-22-2009 12:13 PM
Track Lighting newbie questions GFW Electrical 1 04-18-2008 10:23 PM
