Halogen Puck Light Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 04-06-2010, 01:46 PM   #1
My kitchen was remodeled 8 years ago and two of the halogen puck lights under the cabinet are no longer working. Others in the kitchen are fine. In troubleshooting this, I concluded that it's not the bulbs, not the outlet that the transformer is plugged into and not the switch or any loose wires that I can see.
Does anyone know what I should try next, short of calling in another electrician?
Thank you!
bobssurfin is offline   Reply With Quote
Old 04-06-2010, 05:50 PM   #2
Rewards Points: 1,016
Could there be another transformer somewhere? I have two for my low voltage undercabinet lights. Did you double check the bulbs by swapping them around with known good ones? Have you continuety checked the wires back to the transformer?
Old 04-07-2010, 02:01 AM   #3
Union Electrician
goose134's Avatar
Based on your troubleshooting, I'd say it sounds like a connection that slipped somewhere. Last post said try continuity on the wires. I agree Make sure there aren't any mystery splices buried somewhere that came apart.
Also make sure the wires are secure on the fixture itself. Perhaps there is voltage but no contact at the lamp.
goose134 is offline   Reply With Quote
Old 04-07-2010, 02:03 PM   #4
Thanks. I'll take a look. There are 2 puck lights hooked up to one switch and the one transformer. Both lights are not working. The bulbs are OK. They're just not getting power. Will have to see where the continuity break is.
Old 04-07-2010, 02:10 PM   #5
Master Electrician
Rewards Points: 3,874
Check the voltage coming from the transformer.
brric is online now   Reply With Quote
Old 04-08-2010, 01:29 AM   #6
Union Electrician
goose134's Avatar
Definitely. I didn't realize more than one light on one transformer were not working. Possibly bad tranny.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Halogen Pot light covers? mcvane Electrical 5 03-27-2010 09:51 AM
new light and switch problem please help rebelbull Electrical 1 10-02-2009 06:39 AM
Light switches, dimming problem rsplash40 Electrical 4 12-14-2008 01:04 PM
Wiring Problem in Bathroom notasparky Electrical 7 10-27-2008 06:34 PM
