Halogen Lights-need Help Please!! - Electrical - DIY Chatroom Home Improvement Forum
Old 12-22-2012, 10:44 AM   #1
Halogen lights-need help please!!
I bought 6 halogen bulbs(12v 20w MR8) with sockets also I got 200 w transformer. I assembled it and it works but the light that is coming out of those bulbs is very weak. What's wrong? Please help
yarurban is offline   Reply With Quote
Old 12-22-2012, 11:35 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 230
Switch on the back adjusts the light from not so bright to bright.
Old 12-22-2012, 11:40 AM   #3
There's no switch whatsoever. Am I missing something? I bought bulbs sockets and transformer separately and put it all together.
Old 12-22-2012, 12:11 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,124
Pull one of the bulbs and measure the voltage with the other lights working. You should have around 12Vac.
Old 12-22-2012, 12:16 PM   #5
Unfortunately I don't have tools to do that.
Old 12-22-2012, 12:19 PM   #6
When I connected transformer with lights in line with transformer first. The light behind transformer lighted up brightly but the rest of it went very weak.
Now I connected transformer in the middle of the line and all six bulbs are weak.
Can anyone tell me what's going on?
Old 12-22-2012, 12:22 PM   #7
JOATMON
ddawg16's Avatar
What size wire are you using?
And...I'm assuming that if you unplug all but one bulb, the one bulb is fine?
Old 12-22-2012, 12:31 PM   #8
I pulled all the bulbs but one and it's not working.
I must have wired it incorrectly.
Wires are thick so I don't think it's that.
Old 12-22-2012, 12:39 PM   #9
JOATMON
ddawg16's Avatar
I bet you wired them in series......
They should all be in parallel.
Old 12-22-2012, 12:51 PM   #10
Yes I see my mistake now. I will google how to so it right. I'll post if I fixed it.
Thank you.
Old 12-22-2012, 12:58 PM   #11
JOATMON
ddawg16's Avatar
The fix is easy.....your wiring will basically look like a ladder.....in other words, you will have 3 wires connected on each side of the bulb...power coming in...one side of the bulb....power going out to the next bulb......only the last bulb will have 2 wires on each side.
Old 12-22-2012, 01:02 PM   #12
Something like this?
Old 12-22-2012, 01:10 PM   #13
JOATMON
ddawg16's Avatar
Yep....like that
Old 12-22-2012, 01:44 PM   #14
It's working.
Thank you very much!!
Changing from florecent lights to canned lights, currently 2 sets of wires & I need 4 clueless@wires Electrical 2 04-16-2012 07:21 AM
wire diagram for pot ceiling lights Dan thehandyman Electrical 12 02-24-2012 11:30 AM
Why use halogen lights instead of regular bulbs for outdoor lighting? darsunt Electrical 6 10-13-2009 10:58 PM
New lights in basement CooperChloe Electrical 11 01-11-2009 12:22 PM
halogen lights fitted into a polystyrene ceiling - safe? jono_wales Electrical 1 03-07-2005 03:52 PM
