Halogen Light - Electrical - DIY Chatroom Home Improvement Forum
Old 11-14-2011, 10:13 AM   #1
halogen light
Is there a problem connecting a modern 5 light halogen fixture to old knob and tube wiring? Could this cause a fire?
Sylvie1111 is offline   Reply With Quote
Old 11-14-2011, 10:35 AM   #2
Licensed electrician
Rewards Points: 1,464
Many newer fixtures have a warning label stating they are to be used with wiring having insulation rated 90 degree C. Knob and tube is not 90 degree rated.
Even without the warning the additional heat would bake any remaining life out of the insulation on the wires.
Old 11-14-2011, 11:12 AM   #3
Rewards Points: 1,492
If the fixture is not recessed into the wall or ceiling close to the wiring then all that counts is the watts drawn by the fixture and other things on that circuit. The typical knob and tube circuit is 14 gauge wiring that supports 12 amps continuous or 15 amps intermittent.
Old 11-14-2011, 11:57 AM   #4
Rewards Points: 590
If the fixture is recessed, you still may be able to safely use it with K&T if code allows. You will need to install a new (accessible) junction box at least a foot away from the fixture box. Terminate the K&T there, then run 90 degree NM from that box to the fixture. That way, only properly rated cable will be exposed to the heat. Again, this is a part of NEC (and I believe IEC) that is a little vague, so if your jurisdiction includes one of these codes I'd probably rewire the circuit or use a pendant-type fixture.
operagost is offline   Reply With Quote
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Halogen light fixture voltage reading goingcommando Electrical 10 01-19-2011 09:09 AM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 06:29 AM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
