Halo Recessed Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 09-01-2010, 08:34 AM   #1
I just put Halo Recessed lighting in my kitchen. I had to use the remodel style cans. Because of some pipes in the ceiling, I had to use three shallow cans. I used the 310 trim. I used the short neck bulbs in the shallow cans and the long neck bulbs in the larger cans. I have already tried to adjust the inside of the cans also. My problem is that the short neck bulbs in the shallow cans hang much lower than the long neck. Does any one out there have a solution to this problem.
willyboy is offline   Reply With Quote
How to remove trim from Halo recessed lighting?? rdiggidy Electrical 7 09-05-2013 07:00 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 01:25 PM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 10:47 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 11:21 PM
Confused.....Halo H7ICT Recessed Lighting Question tigerbalm2424 General DIY Discussions 5 01-09-2008 08:21 AM
