Halo Canister Light Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 12-27-2005, 07:21 PM   #1
I am finishing my basement. How many canister lights can I run off a 15-amp circuit breaker using 14-2 G type wire? The canister calls for 75w R30 light bulbs. Thanks for any help.
tvinson9 is offline   Reply With Quote
Old 12-27-2005, 07:43 PM   #2
World famous jerk.
You may install up to 1800 watts of lighting on a 15 amp circuit (14 gauge) for a residential application, and 1440 watts for a commercial application. If you're installing fixtures on this circuit with 75 watt lamps, you may install 24 fixtures in a dwelling, 19 fixtures for commercial.
In your other thread, you mentioned that you were using low voltage recessed cans. Are we talking about the same cans, or is this a different area?
mdshunk is offline   Reply With Quote
Old 12-27-2005, 08:31 PM   #3
Thanks for the reply. I am using Halo H71CAT Canisters.
Old 12-28-2005, 09:41 AM   #4
Watts/Volts=Amps Amps x Volts=Watts
you are only supposed to load a circut by code 80% of its maximum(residential) so 80%=1440 watts =19cans.
donkey is offline   Reply With Quote
Old 12-28-2005, 09:47 AM   #5
I thought only in commercial can you have a "continuos load" application where you can use 100% of a circuts capability,in residention its 80%.Mainly because nothing will ever be "plugged in" or added to the commercial lighting circut,where in a residential lights and plugs are allowed to be on one circut so the circut is down graded since the load of the circut can constantly change by the hour/min.
Old 12-30-2005, 06:34 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,876
No, it's the opposite. Almost nothing in a residential setting is considered a continuous load.
Almost everything in commercial is, or can be. Especially lighting.
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 07:22 AM
Holding ceiling light fixrure during installation jdemaray Electrical 2 01-15-2007 09:45 AM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 08:11 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 07:02 AM
