HALO Airtite Sealing In Thick Ceiling - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2009, 01:55 PM   #1
HALO Airtite Sealing in Thick Ceiling
I am installing 4" HALO Airtite cans in toilet/shower area using new construction cans and one area of ceiling is 5/8 sheetrock and the shower stall will have 5/8" plus thickness of tile on ceiling. The ring that extends down from the HALO can is only 1/2" (I assume for 1/2" sheetrock) so I am not sure how to properly get the shower trim piece with the sealed lense to properly seal for the extra thicknesses of my ceiling. If the trim is tight against the surface, that means there is still an open path for the heat within the can area to pass directly to the edges of the sheetrock cutout and this would seem to present a fire hazard over time if it gets too hot. Are there metal rings to extend for the thickness or some kind of special sealing material to fill this area?
DAKRO is offline   Reply With Quote
Old 07-25-2009, 12:09 PM   #2
Rewards Points: 82
All recessed fixtures are adjustable, up and down. You adjust the can after the drywall or tile is up. Bring the can down as close to flush as you can. But not all the way flush. All rings have adjustable spring clips. These clips (spring with long straight ends) allow you to engage the fixture and allow you to move it up and down also. The depth you mention should be fine with most any recessed fixture. I hope this makes sense to you.
Tags
halo , sealing , sheetrock , shower , tile
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 04:29 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 05:18 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
