Halo 3" Recessed Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 05-24-2009, 12:57 PM   #1
Unhappy
Halo 3" recessed lights
Good afternoon,
I was hoping to get some advice on a house I just bought. I am going to be removing the popcorn ceiling and replacing it with knockdown texture. I have a living room 12X14 that currently has a ceiling fan in the center and track lighting above the couch.
I want to install the halo 3" cans H38ICAT. Will 7 be enough? 50 watt bulbs
3 along the hall entrance
2 on eith side of the fan
2 at the other end.
http://i611.photobucket.com/albums/t...nolehouse6.jpg
scottwchicago is offline   Reply With Quote
Old 05-24-2009, 02:16 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
The number of lights is always a tough question. Besides the square footage there is also ceiling height and wall covering/paint color. There is no set formula. If you put in too few lights you will be more unhappy than if you put in more. If more then you can use the dimmer. If less then with those small cans you can't use bigger bulbs.
I would go with bigger (at least 5") and more cans.
Here is THE H38ICAT pdf
http://www.cooperlighting.com/specfiles/pdf/Halo/ADV060300H38ICAT.pdf
Disclaimer
& Stay Safe
.....Bob Lavery
Old 05-24-2009, 03:10 PM   #3
Thank Bob, These lights are not cheap once you add in everything. I like the look of the small 3", I will definitely add a few more. thanks
Old 05-24-2009, 07:32 PM   #4
Electrical Contractor
kbsparky's Avatar
I'd install them as originally outlined. If that isn't enough, then you can add more between the fixtures.
Tags
recessed lighting
Adding 4 Recessed Lights to single wire themayor Electrical 5 02-05-2009 04:08 PM
Recessed Lights problem Boycer88 Electrical 15 02-01-2009 07:23 PM
what are the tricks to insulating above recessed lights? red86yota Building & Construction 8 01-29-2009 06:54 PM
wiring recessed lights question. SubSailor Electrical 2 02-25-2008 12:39 PM
Formula for changing lights to recessed bulbs? Jemo Electrical 12 01-26-2007 05:02 PM
