Hallway Light Flickering When First Turned On. - Electrical - DIY Chatroom Home Improvement Forum
Old 09-23-2009, 06:47 AM   #1
Rewards Points: 408
Hallway light flickering when first turned on.
I've noticed it a few times now. When I first turn on the hallway light it has some minor flickering for 2-4 seconds and then stops. If I turn the light off and back on it does not do it it seems to only be when I turn it on from a cold start. Recently a lot of more lights were added to this circuit but they were not on at the time of this but could that still have something to do with it?
* The first time I saw it I changed out the light bulb but that didn't help.
RyanD is offline   Reply With Quote
Old 09-23-2009, 07:12 AM   #2
Rewards Points: 1,548
The switch could be wearing out, including for such reasons as old age.
A typical light switch will handle several light bulbs.
When installing a new switch, wrap the wires around the screw terminals to attach them. Don't use the push in holes in back unless a screw is provided and absolutely needed to hold the wires in place back there.
Old 09-23-2009, 11:31 AM   #3
Rewards Points: 246
Is it a fluorescent light or incandescent? If it's a fluorescent theres little you can do. (In some instances "older models" a starter will be present in the fixture. You could try replacing that). Replacing the fixture is the only other option.
If it's an incandescent, tighten or replace the bulb.
If it worked before you worked on it. You did something wrong.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Arc Fault Break Tripping when any light switch turned on elab1 Electrical 60 11-20-2009 01:24 PM
Wire hot with light switch turned off dangerouswithtools Electrical 3 06-17-2008 07:56 AM
GFCI receptacle gets tripped by hallway light proofer Electrical 10 03-17-2008 07:29 PM
Wall outlets stay charged even when light switch is turned off proofer Electrical 33 01-25-2008 04:43 PM
