Half The Outlet Is Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 01-17-2009, 11:19 AM   #1
half the outlet is not working
hi i have my living room that has all the outlets not working on top any ideas?
tskmercer is offline   Reply With Quote
Old 01-17-2009, 11:21 AM   #2
Electrician
Half Switched receptacles, hit the light switch that you never knew what it did before now...
chris75 is offline   Reply With Quote
Old 01-17-2009, 11:21 AM   #3
Rewards Points: 85
is there a switch on the wall anywhere? That would be the first thing I would check, some homes are wired that way
mferguson0414 is offline   Reply With Quote
Old 01-17-2009, 11:22 AM   #4
Rewards Points: 85
LOL, answered at the same exact time!!
Old 01-17-2009, 11:24 AM   #5
Rewards Points: 160
Yes, the one behind the tall plant.......LOL
Old 01-17-2009, 11:25 AM   #6
Electrician
Grandfather clock, painting, you know the story...
Old 01-17-2009, 11:30 AM   #7
Electrical Contractor
kbsparky's Avatar
Yeah, we had a service call last year with similar findings.
Seems that the old fogies "lost" power to an outlet in their living room, and could not figure out why.
I asked them over the phone about hidden wall switches, and you can guess their response: We have NEVER had any switches in that room, etc, etc.
Well, I got there, and discovered one hidden behind a large piece of furniture, flipped it, and voilą! The outlet worked again.
Upon further investigation it was determined that they recently had some grandchildren over for a visit, and one of them must had done some "exploring" around the house, and switched the outlet off.
Old 01-17-2009, 01:01 PM   #8
Look for a switch...
rgsgww is offline   Reply With Quote
Old 01-17-2009, 01:05 PM   #9
Rewards Points: 894
I assume that these receptacles did work at one time.
If not, maybe someone removed the tabs and wired to the bottom screws.
Ultrarunner2017 is offline   Reply With Quote
Old 01-17-2009, 01:50 PM   #10
LMAO i found the switch
lol thanks so much for the advice, you saved me alot of time and money
Old 01-17-2009, 02:04 PM   #11
Electrician
You can still send a gratuity check...
Old 01-17-2009, 02:06 PM   #12
kbsparky's Avatar
At least you found yours before calling a contractor to troubleshoot your outlets!
Image the embarrassment my customer felt when I showed them the "hidden" switch, after they paid me $75 to look behind that piece of furniture to find it!
I found it quite amusing, since I did try to encourage them over the phone to look for it first, before I had to go over there and hold their hand ...
Old 01-17-2009, 02:08 PM   #13
Electrician
My favorite call is when a light all of a sudden stops working, my first response is "did you change the lamps?" Always get a yes answer till I get there and change them and it magically works...
Old 01-17-2009, 02:21 PM   #14
kbsparky's Avatar
Thread hijacked now ... ;)
Yeah, had one about 20 years ago, from a bunch of college kids living in a house.
The light at the backdoor was not working, so they said. I took my tester and checked the socket, all seemed to be fine to me. So I went into the truck and got a 60 watt bulb, screwed it in, and sure enough, the light worked perfectly!
They protested "...but we changed the bulb and it didn't work!"
Seems that they took a hot bulb from a lamp in the living room, shook it near the ear to be sure it was "still good" and then installed it in the outside light.
Of course, you should not shake a bulb to hear if it's still good, because in so doing, you can cause the filament to break. Especially if the bulb was lit when you removed it from the lamp, and the filament was still hot!
Old 01-17-2009, 03:18 PM   #15
Rewards Points: 24
I've had Friends and family call me and tell me their outside outlets aren't working and i tell them to check the gfi in the bathroom, basement, garage, etc. They say they have. I'll stop over and find the tripped gfi for them, seems like sometimes it's easier to let someone else handle anything that comes up rather than try to figure it out themselves.
ponch37300 is offline   Reply With Quote
Outside outlet stopped working mclontz Electrical 13 12-11-2008 09:37 AM
Wall outlet not working Bubby106 Electrical 7 11-25-2008 08:35 AM
Outlet stopped working nealt Electrical 9 07-19-2008 03:46 PM
Outlet not working? Madnpc Electrical 3 12-07-2007 05:51 PM
Outlet in garage quit working Thirdeye Electrical 10 07-01-2007 10:32 PM
