Old 08-27-2008, 12:59 AM   #1
Half moon fixture
I recently installed a half-moon fixture(similar to the one below) in my basement hallway. There is a sheet of drywall right above it, probably about 6 inches away. It has cracked the corner bead and a few other spots from the heat. Is this a fire hazard or does drywall have poor flammability rate? I don't care if the drywall cracks, its a hallway and nobody stops and looks. Should I just move to a fluorescent bulb that produces little heat?
n0c7 is offline   Reply With Quote
Old 08-27-2008, 08:09 PM   #2
Half moon fixture
is the bulb the right wattage for the fixture....? If the wattage is to great you will dry out the wires behind the fixture and that could cause a fire...replace with a compact florecent bulb they run much cooler
Mightyidi is offline   Reply With Quote
Old 08-27-2008, 08:20 PM   #3
Electrician
SD515's Avatar
Half moon fixture
Would be my suggestion too if the light isn't on a dimmer. And my first wonder was if the bulb was too great a wattage also.
Old 08-27-2008, 11:56 PM   #4
Half moon fixture
It's a 100W bulb, fixture is insulated and rated to 100W. The issue is how close the fixture is mounted to the drywall above it, and being an open fixture the heat has nowhere to go but up.
Old 08-28-2008, 12:33 AM   #5
Electrician
SD515's Avatar
Half moon fixture
Isn't physics great!!
You say there is a sheet of drywall above it. A ceiling I presume?? Double check the instructions about how close it could be mounted to a ceiling??
My concern is the heat from the 100W you mention. If it's a screw in type bulb, and not on a dimmer, I'd try a CFL, for less heat. If it's a different type bulb, I'd get a lower wattage of that style.
Old 08-28-2008, 12:44 AM   #6
Half moon fixture
The instructions were generic for 5 types of similar fixtures(not even the one I bought) and didn't even mention how to ground the sucker properly... but hey it matches the rest in the house!
No dimmer, its a hallway light so we need it bright to get up/down stairs. It's a screw-in type, I'm sure a CFL would fit.
Old 08-28-2008, 12:49 AM   #7
Half moon fixture
Here's a pic. You can see the drywall tape starting to bleed and peel.
Old 08-28-2008, 01:02 AM   #8
Electrician
SD515's Avatar
Half moon fixture
Nice light.
Yeah I see break in the corner of the soffit. I'd try a 23W CFL.
Installed Fixture, Unexpected Result bigphaty Electrical 1 06-17-2008 01:25 PM
A faulty bulb or a faulty fixture? don54 Electrical 5 12-25-2007 05:38 PM
double-ended halogen fixture bulbs stop working watt-ever-ny Electrical 6 11-20-2007 06:25 PM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 08:51 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
