Hair Dryer Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-02-2009, 08:23 AM   #16
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
Originally Posted by KE2KB View Post
Actually, a hairdryer is a mainly resistive load, so if the voltage drops, so does the current, and thus the wattage.
FW
Oh yes thanks for correcting me.
There is no such thing as a stupid question, but there is such a thing as an ignorant person, with a question, trying to learn.
Pudge565 is offline   Reply With Quote
Old 02-02-2009, 08:32 AM   #17
Rewards Points: 900
Originally Posted by Yoyizit View Post
Had a customer once where it took a good ten minutes before the 1875W tripped the 15A breaker.
I suppose that if it is very cold where the breaker is located, the time/temp curve would be changed, and it would take longer to trip.
My panel is located (as most are) on the foundation wall. It's probably around 10C at the panel right now. Now this has me interested in looking up the curve for the CH breakers.
FW
Ultrarunner2017 is offline   Reply With Quote
Old 02-02-2009, 11:40 AM   #18
looking up the curve for the CH breakers.FW
Finding them on the Internet is like pulling teeth, but they are full of interesting info: The one-cycle trip time, the minimum trip time regardless of current (probably limited by the inertia of the gizzards) and the current at which the thing will never trip.
Part of the curve follows an IT relationship, other parts do not. Underneath this strange curve are asymptotes representing ideal, design-goal performance, but they are not very apparent by looking. One trip mechanism response kind of blends into the next one.
The 20A CB I took apart had a 2w, 2" long, strange looking resistive wire in it to handle the IT part; I couldn't readily see how they did the magnetic part.
Old 02-02-2009, 06:08 PM   #19
Rewards Points: 900
Do all CB's use both temp and magnetic elements?
I recall that magnetics were always more accurate, and would trip at the same current regardless of ambient temp.
The old FPE I had were strictly a thermal device, so if the panel were outside in the middle of winter, breakers would require a lot more current before they trip.
Somehow, I have the idea that CH are magnetic, but then I don't really understand that much about the innards of CB's.
FW
Old 02-02-2009, 08:11 PM   #20
http://en.wikipedia.org/wiki/Circuit_breaker
Old 02-02-2009, 08:24 PM   #21
Rewards Points: 150
KE2KB:
I've been reading thru this thread and I decided to do some investigating regarding the hair dryer question. My wife has a 1875 watt hair dryer too so I took an amp draw reading when it was on high. The voltage was 120 and the amp draw turned out to be 13.
I also checked this out using ohm's law. The voltage was 120 and the resistance of the hair dryer was 9.3 ohms. Current=voltage/resistance. Current turned out to be 12.9 volts. I was getting 13 with my clamp on meter.
Steelhead is offline   Reply With Quote
Old 02-02-2009, 08:29 PM   #22
Only if hot resistance = cold resistance. For Nichrome it pretty much does, not so for tungsten.
Old 02-02-2009, 09:21 PM   #23
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
KE2KB:
So the actual wattage of this "1875 watt" hair dryer was only 1560 watts.
False advertising?
Old 02-02-2009, 09:47 PM   #24
False advertising?
Well, this "mistake" is in favor of the seller, since more power = more money for the seller.
And, does the seller ever make "mistakes" not in his favor (which he should, approx. half the time)?
Old 02-02-2009, 10:03 PM   #25
I really don't think the word "mistake" is appropriate here.
Old 02-02-2009, 10:22 PM   #26
Idiot Emeritus
Rewards Points: 1,492
Sorta like the 5 HP air compressor....Runs on standard house current.
If I figured out how to get 5 HP out of a 20 amp 120 volt circuit, I bet I wouldn't be building air compressors!
Rob
micromind is offline   Reply With Quote
Old 02-02-2009, 10:34 PM   #27
joed's Avatar
Rewards Points: 13,368
False advertising?
If you use the high limit of the electrical grid of 130 volts and the 9.3 measured reading then you get 1817 watts. It's all relative to how you rate them.
Same thing happens with compressors. They over rate the HP by stating it as PEAK HP. It's better now for compressors since the manufactures lost a law suit for stating the peak HP instead of the continuous running HP.
http://www.lawcash.com/attorney/3392...nc-lawsuit.asp
Old 02-03-2009, 09:49 AM   #28
Rewards Points: 900
I recall way back when stereo amplifiers were allowed to be rated for "peak music power", which is much higher than trur RMS @ 1Khz.
When I needed to purchase a sub-amp for my Subaru Forester, I had to buy an 1100W, because that's the smallest I could find.
What would I want 1100W in my small SUV for?
My sister bought an 1875W hair dryer from Harmon yesterday for under $25. Looks decent. Has the GFCI (actually, I think there's another term for these devices) plug of course.
I'm still going to add receptacle on a 20A branch to her room for the dryer.
FW
Dryer exhaust question KC Brick Layer Plumbing 3 12-08-2008 08:47 AM
Electric Dryer wiring/plug question SpaceCrawler Electrical 6 08-26-2008 04:33 PM
Question about dryer venting jimithing78 HVAC 10 08-26-2008 11:37 AM
Dryer Vent Question jlaky2000 HVAC 2 03-13-2008 08:22 PM
Dryer exhaust question Felipon Appliances 6 02-03-2008 11:29 AM
