#1 |
Hair dryer question
Good evening;
I'm curious; If a hair dryer is rated at 1875 Watts, then it should draw 16A. That should mean that it would come with a 20A plug, since it will trip a 15A breaker, right? If this is true, then someone must be playing games with the public. I have never seen a hair dryer with anything except a 15A plug or 15A GFCI plug. So, what gives? Is the power rating just a selling point? Reason I am asking this is that my sister needs a new one, and all she can find are 1875 Watts. I told her that she will not be able to use it on the highest setting, because the receptacle where she usually uses it is on a 15A circuit. I am planning to either replace the wiring to the specific receptacle where she uses the dryer the most (it's not in the bathroom), or add a completely new receptacle on a 20A circuit that doesn't have any continuous loads. So, if she buys the 1875 Watt model tomorrow, will she still be able to use it on the 15A circuit, with 15A receptacle if she doesn't use the highest setting? I am aware that the bathroom is required to have 20A GFCI circuit. Ours does not, but I plan to rewire someday. Thing is, she uses the thing in her bedroom anyway. I assume I won't need a GFCI there, but maybe an AFCI? Thanks for your help/advice. FW
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#2 |
Hair dryer question
Would a 16a draw trip a 15 amp breaker? Get your meter out. In the mean time maybe she could run it on a lower setting.
Gary |
#3 | |
Hair dryer questionQuote:
I don't have a meter capable of reading 16A. I only wish that the electrician who wired the room hadn't cheaped out and run #14/2. I always use 12/2 for my work, even if it's a 15A branch, with hopes of upgrading to 20A someday. FW
#4 |
Idiot Emeritus
Hair dryer question
I realize your breaker is CH, I don't have CH trip curves handy, but according to the Square D book, a QO 15 amp breaker will hold 16 amps anywhere from 200 seconds (3 minutes) to indefinately.
A 14/2 NM will have no problem with 16 amps continuously. If the voltage at the main breaker is exactly 120, it'll be a bit less at the receptacle, therefore the amperage will be less as well. If the 14/2 is 50' from the panel to the receptacle, there will be about 4 volts drop in the wire. Starting at 120, this will result in about 15.1 amps. Almost any 15 amp breaker will hold 15.1 amps continuously. Rob |
#5 | |
#6 | |
I told my sister to avoid using the highest setting until I have a chance to upgrade the situation. Before the 42 position C&H panel was installed (with upgrade from 100A to 200A), we had an FPE. Those breakers weren't worth a dime, were completely unreliable, and dangerous. The upgrade was performed when we had an addition put on the upstairs. Like I said though; if I had wired the new addition, I would have used 12/2 and run 20A branches. As it stands, they ran two 20A (12/2) branches for the AC units, and only one 14/2, 15A for other receptacles in two rooms. IMO, this is not adequate. But perhaps because each room already had receptacles, and the addition was only making these rooms larger, the electrician did not feel the need for more capacity. It did pass inspection though. FW
#7 | |
Electrician's Helper
Accually if wattage remains the same and voltage drops amerage will increase. Due to the fact that I=P/E so 2400 watts on a 240 volt and 120 volt circuit. So 2400/240=10amps now 2400/120=20amps.
There is no such thing as a stupid question, but there is such a thing as an ignorant person, with a question, trying to learn. |
#8 | |
Licensed Electrical Cont.
Hair dryer question
I can only assume the manufacturers are doing the same thing as with GMRS radios when they claim 20-30 miles when they typically only do 2-3 miles tops.
If you run 12 use a 20A breaker. If you run 14 use a 15. Except for long runs to counter voltage drop there is NO reason to use a 15A breaker on #12.
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
#9 | |
I hope this is only a temporary situation<g> Eventually, I would like to have all the receptacles wired with 12/2 on 20A branches, and lighting with 14/2 on 15A branches. Since this house was wired 80 years ago, there are branch circuits with lighting and receptacles. That was back when no one had appliances drawing 15A or more! FW
#10 | |
Being a HAM, I understand that logic. It's the 'more is better' philosophy. I've had trouble getting more than a few miles on 2m with 5W into a 5/8 whip, and then I have made contacts over 200 miles with the same radio and antenna from the Catskill mtns! That's not to say that using the 1875 watt hair dryer on top of the Catskill mtns will dry your hair any faster than it will at sea level, but you know what I mean ![]() FW
#11 |
Hair dryer question
1875 is best case marketing number. It is likely that the dryer doesn't draw the full 1875 when used. If they do the test with maximum allowable voltage of 130 volts and you only have 110 volts you won't be drawing the full watts.
#12 | |
FW
#13 |
Xtreme DIY'r
Hair dryer question
I had the same problem & my house is from the 50's
And they top wired instead of wiring from the basement So I am adding outlets on some walls that do not have outlets The 12a vacuum was a problem My wife actually used her hair dryer in another room on high for hair drying. The bathroom circuit was extended off the rest of the house & would not handle much load. Since I had easy access & had to have plumbing done (wall ripped out) it made sense to run a dedicated 20a fairly quickly |
#14 | |
I just finished installing a new 20A branch to a receptacle in my upstairs hall, mostly for the vacuum, which can draw up to 12A. I will install a new receptacle for my sister in her bedroom off the same branch, since it is extremely unlikely that both the vacuum and hair dryer will be used at the same time. When I added the receptacle in the hall, I pig-tailed to 30ft of 12/2 from it to a j-box in my closet with the cable coiled up. I always plan ahead<g> I still have to add at least one more 20A line upstairs for the bathroom. I've got a closet wall that lies directly above a wall downstairs, and have been using it to pull power, CATV, and CAT5 cables. It's great to have a closet where I can rip out walls and don't have to repair right away! FW
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by KE2KB; 02-01-2009 at 11:26 PM. |
| Display Modes | |
| Dryer exhaust question | KC Brick Layer | Plumbing | 3 | 12-08-2008 09:47 AM |
| Electric Dryer wiring/plug question | SpaceCrawler | Electrical | 6 | 08-26-2008 05:33 PM |
| Question about dryer venting | jimithing78 | HVAC | 10 | 08-26-2008 12:37 PM |
| Dryer Vent Question | jlaky2000 | HVAC | 2 | 03-13-2008 09:22 PM |
| Dryer exhaust question | Felipon | Appliances | 6 | 02-03-2008 12:29 PM |
